About to order my Yella Terra's. Spent the last while working on finishing up some unfinished work the machineshop left for me to do...
Anyways the heads, valves and everything is setup for a .6 lift to run the XPZ and a bit more. Pedistal cut and everything. Any reason I should consider running a 1.7 Yella Terra over a 1.6? I have heard of guys with the smaller cams like the VS cam doing it but, recent;y heard of another member running a higher lift rocker with a custom cam grind similar to the XPZ I'm using.
Thoughts?
