Thread: Maf fail
Results 1 to 6 of 6
  1. #1 Maf fail
    SE Level Member theone2043's Avatar
    May 2008
    Pocono's
    I think I have been plagued with the P0102 code since I did my top swap last fall. For whatever reason, I have over looked it till now. I have it narrowed down to the fuse is blown. I replaced it three times and each one blew. Can it be the wiring for the 97 gt is different then for the gtp newer maf?
  2. #2 Re: Maf fail
    It isn't just the wiring last I checked...it was the entire throttle body.
  3. #3 Re: Maf fail
    May 2008
    Pocono's
    I know the tb is different but that would not cause the p0102. After looking at advance auto online site, the gt and gtp maf for 97-98 are the same. I'm going to go home and look for my stock gt maf and swap it in.
  4. #4 Re: Maf fail
    May 2008
    Pocono's
    Never mind I found out I have a 98 blower and tb, so it should be the same maf that was used on my gt, I am going to switch them tonight and see how it responds.
  5. #5 Re: Maf fail
    May 2008
    Pocono's
    At this point it has nothing to do with the MAF sensor. It has to be a wire issue. With a new fuse and the maf unplugged, as soon as I put the car to the on position, it blows the fuse. I threw a 30 amp fuse on it and it works fine. What are the side affects to running a 30 amp fuse temporally till I trace down what is causing this fuse to blow.
    What all runs on this fuse? Are the o2 also using this fuse?
  6. #6 Re: Maf fail
    GT Level Member skidoojames151's Avatar
    seattle
    the issue is now you could start a fire because the wire is probably shorted somewhere
  1. Fail
    By Will5600 in forum General Tech Discussion
    Last Post: 11-08-2009, 06:46 PM
  2. Fail FTW
    By mpiacent in forum Track Sessions and Kills
    Last Post: 08-25-2009, 01:04 PM
  3. FAIL!
    By J GTP in forum Off Topic Discussion
    Last Post: 06-17-2009, 11:54 PM
  4. FAIL!
    By SlowM90 in forum Off Topic Discussion
    Last Post: 02-26-2009, 02:14 AM
  5. FAIL
    Last Post: 11-01-2008, 03:45 PM
