I've had an intemittant problem with my car stalling while driving and not restarting. took it to the dealer and they first replaced the fuel pump module and a inaccurate fuel level sensor in june 16 2008. I had the same issue again with the car stalling on July 1, 2008 took it in and they said no codes stored in any modules, loss of spark when cranks wont start. No signal from PMC the check crank sensor it was ok. they repalced and programmed PCM it started then stalled. no power from UBEC to starter at times on purple wire. They replaced UBEC for intermittant open at starter relay & IGN swich for high ressistance through cranking circuit. parts replaced PCM 3.670, Block 2.483, B/0 chg, switch 2.188
picked car up on July 11 same issue on on July 15 dealer replaced the crank sensor and switch parts switch 1.800 and SEN ASM 2.383 picked car up on July 23. Happened again Nov 27,2009 they again replaced crank sensor and ignition module. Has any one else had these issues? any help would be great
