Thread: abs light on = hard turning
Results 1 to 4 of 4
  1. #1 abs light on = hard turning
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    ok when the abs light is off it is easy to turn but when it come on it gets harder to turn the wheel. what could be the problem? the light is not always on just comes on some times and the tcs light comes on to.
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  2. #2 Re: abs light on = hard turning
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    Prob have a bad wheel bearing or u have a short in the wiring?
    Try a scan tool and it could tell u were its coming from?
  3. #3 Re: abs light on = hard turning
    Grayslake
    would it have to be a special scan tool or no?
  4. #4 Re: abs light on = hard turning
    Donating Users kfish's Avatar
    Ohio
    yes, not just any scan tool can read abs codes. take it to the dealer and have them scan and give you the codes. do gtps have variable steering assist? if so maybe when the abs is on, the pcm switches to low assist causing hard turning?
  1. Trouble turning over
    By Halfy in forum General Tech Discussion
    Last Post: 08-23-2010, 11:49 AM
  2. Having problem my car keeps on turning off
    By krazyog1 in forum 04+ Specifics
    Last Post: 09-09-2009, 08:49 PM
  3. Ignition not turning
    By alee90 in forum General Tech Discussion
    Last Post: 03-08-2009, 10:07 AM
  4. Turning a 01' SE into a GT
    By Dangerous313KidInAPrix in forum Visual/Body Modifications
    Last Post: 03-03-2009, 09:17 PM
  5. TCS not turning off
    By Keet04GTP in forum General Tech Discussion
    Last Post: 08-06-2008, 02:57 PM
