Thread: Cam time
Results 1 to 20 of 30
  1. #1 Cam time
    Charles City, IA
    I decided my engine is coming out this winter to fix a few small leaks and I am going to cam it while it is out. I have ported heads and have no problem machining down the valve guides. I will however not be running over sized valves or an inter cooler just running meth. It will be driven quite a bit on the street. I have a **** box to drive around some days, but the gp will still be driven a lot. I am thinking between an xp, S1X or S2X cams. Any other ideas would be great. Dont plan on putting the heads on a flow bench so I wont get a custom grind. I also don't want to run a double roller timing set if I can avoid it. Probably going to run like 105 springs.
    Hows that for telling ya what I want
    SMGPFC Two Nipple General
  2. #2 Re: Cam time
    S1X or XP...I loved my XP...get it...
  3. #3 Re: Cam time
    Charles City, IA
    Should have saved your xp for me.
  4. #4 Re: Cam time
    should have called DIBS like every other damned vulture
  5. #5 Re: Cam time
    Charles City, IA
    You should have know I would want it later. Way to let a fellow nick down. lol
  6. #6 Re: Cam time
    I have the S1X and love it. Either S1 or XP would be great for what you are saying. Then later on if you want a little more and you milled the valve guides like you mention. Add rockers. That way you retain the nice idle and streetability of the cam you picked out, but add a little more lift.
  7. #7 Re: Cam time
    Aug 2008
    Long Island, New York
    yea ive heard the xp is good, i want it some day after i do my meth and trans build
  8. #8 Re: Cam time
    Jan 1970
    Maquoketa, Iowa
    The S1X has worked some wonders for a few cars around here. New stock timing chain and dampener on some 105's also has worked well thus far.
  9. #9 Re: Cam time
  10. #10 Re: Cam time
    Apr 2009
    stockton ca
    well ill let you know how the s1x feels in a couple weeks
  11. #11 Re: Cam time
    Jan 1970
    Maquoketa, Iowa
    YouTube - 98gtp 12.98
    The silver car is a GenV S1X setup, the Black car is a XP, fullsize intercooler, fully ported gen3. So far the S1X had a pb of 12.3 and the black car a 12.7.
    Craig128.flv video by jrod699 - Photobucket
    This is a regal I tuned, S1X GenV, the tune was still on stock timing tables as the fuel was being a ***** and would not stay consistant or settle down at all, the car has more in it.
  12. #12 Re: Cam time
    Charles City, IA
    I have been leaning towards the S1x, just wanted some feed back on them.
  13. #13 Re: Cam time
  14. #14 Re: Cam time
    Charles City, IA
    ^ yeah it is. If I was not going to dd it I would have a Stage 4 blower cam.
  15. #15 Re: Cam time
    I need to go to Iowa when I get this car done...you guys got some slick rides up there. I've got family in Conrad and Beeman...TINY azz towns...might have to stick around when I visit them over a weekend and take a roadtrip.
    Anywho...FWIW...even though the S1X is a better cam there is nothing wrong with the XP IMO...it is still a great cam.
  16. #16 Re: Cam time
    Charles City, IA
    Conrad is pretty close to cedar falls race way.
  17. #17 Re: Cam time
    Charles City, IA
    So now I am debating the S2x cam. Anyone ever run it or know someone who has? I figure I am spending the money might as well go a little bigger.
  18. #18 Re: Cam time
    why would you run the s2x? i dont really think anyone runs it. if youre going bigger you might as well run an IS3.
  19. #19 Re: Cam time
    Charles City, IA
    What you like I could pull for mileage with that 25ish?
  20. #20 Re: Cam time
    with a good tune, why not? you shouldnt be looking for good mileage if youre trying to run a big cam anyway.
    stick with the s1x.
  1. all this time ...
    Last Post: 08-15-2009, 12:33 AM
  2. First time here
    By manticore in forum Introductions/Noob Questions
    Last Post: 06-17-2009, 05:15 PM
  3. 0-60 Time
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 12:42 AM
  4. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
  5. Had a little time!
    By ldyzluvdis06 in forum Visual/Body Modifications
    Last Post: 05-30-2008, 09:48 AM
