I decided my engine is coming out this winter to fix a few small leaks and I am going to cam it while it is out. I have ported heads and have no problem machining down the valve guides. I will however not be running over sized valves or an inter cooler just running meth. It will be driven quite a bit on the street. I have a **** box to drive around some days, but the gp will still be driven a lot. I am thinking between an xp, S1X or S2X cams. Any other ideas would be great. Dont plan on putting the heads on a flow bench so I wont get a custom grind. I also don't want to run a double roller timing set if I can avoid it. Probably going to run like 105 springs.
Hows that for telling ya what I want![]()
