Thread: header interest important!!
Results 41 to 60 of 74
  1. #1 Re: header interest important!!
    Banned - Busted For Scamming
    Feb 2009
    Im bumping this thread because i have decided to go through with this, ordering the stuff tonite. If i could start a list of potential interest that would be great, to see how many sets to be made first. I will provide pics of the headers and installed pics as well, guaranteed to fit.
  2. #2 Re: header interest important!!
    Feb 2008
    The "hump" sticks down a fair amount. The one set I put on, the guy later took it to an exhaust shop and had them remove the hump. As for the interlock, the local I helped only had that part there for a week. It was removed when the hump was taken out. It sealed for a week, at least...
    Logan, I'm glad to see that you're going through with this. I'll be excited to see the outcome.
  3. #3 Re: header interest important!!
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    So where does this stand? Or is it another one of those "I'll do it" than you never hear anything about it again?
  4. #4 Re: header interest important!!
    Apr 2009
    stockton ca
    well Im intrested And will have money after jan 15th
    im still looking at ssauto but if you get a set in a car and pics and all Im intrested
  5. #5 Re: header interest important!!
    PACESETTERS!! And weld them...best budget header if done right.
  6. #6 Re: header interest important!!
    Charles City, IA
    SSAC not welded even better budget headers.
    SMGPFC Two Nipple General
  7. #7 Re: header interest important!!
    SE Level Member Amb4's Avatar
    Nov 2009
    Canada
    I'm interested I'm looking for a set after the new year!
  8. #8 Re: header interest important!!
    Funky 2.5" DP fail^^
  9. #9 Re: header interest important!!
    Feb 2008
    The SSAC's? They've got a 3" DP.
  10. #10 Re: header interest important!!
    Feb 2009
    Ok guys heres where we are at. Apparently there is interest so we will go through with this. Im working with a couple of buddys on this as it needs to be financed to get the materials. Ill let you know when i get the stuff, they should be ready by mid january. I have a couple questions for potential buyers:
    1. On the downpipe, for clearance issues im thinking of cutting off the 3 bolt flange and welding on a v band clamp its lower profile to ensure it doesnt interfere with the firewall. Thoughts?
    2. On the crossover, would you be interested in me adding a v band connection towards the rear so that you can take apart the crossover in case you had to remove the tranny and it would make header install easier. The v band clamps dont leak so that wont be a problem. Thoughts?
  11. #11 Re: header interest important!!
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    IF you make them like this, they will sell.
    Don't use cheap materials
    Use 304 or 321 SS
    interlock flexes
    3/8 or 1/2 in SS flange
    SS vibrant V-band clamps have a nice male/female lip which ensures perfect sealing
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  12. #12 Re: header interest important!!
    Donating Users blowfishRus6's Avatar
    g.a.
    ^^^^^ i kinda like that design. working on the Y pipe trying to clamp it down and everything while its on the car is kind of a *****. if the back header would not be an install issuie to get it on/in the car then this looks like it would simplify installation. and if it seals up with those clamps, then why not.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  13. #13 Re: header interest important!!
    Feb 2009
    Thats basically what i was getting at. Who made those?
  14. #14 Re: header interest important!!
    Schaumburg, IL
    SSAC base headers modified with vband, flexes, and downpipe modified
  15. #15 Re: header interest important!!
    May 2008
    staten island,NY
    those look like a set of slp's or ssac, that had vbands welded on. looks like a good design
  16. #16 Re: header interest important!!
    Feb 2008
    V-band clamps are definitely the way to go.
    The design of the picture above is pretty much perfect! The flex could be placed post-bend in order to allow the pipe to hug the tunnel a bit better...
    Can we make the EGR an option? I don't have it, and would prefer not to have to block it off or have it welded shut.
  17. #17 Re: header interest important!!
    Feb 2009
    Most definitely. Egr can be an option. Basically im buying headers and modding them like the above ones, except that the crossover wont have a flex as it doesnt need one, and the downpipe flex is on the straight part, not the slanted as above. I can remove the egr and weld it shut if you need.
  18. #18 Re: header interest important!!
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    if you mean the horizontal part of the pipe I wonder how the flex would handle the compression rather than the side to side movement if it were in the vertical part of the pipe?
  19. #19 Re: header interest important!!
    Schaumburg, IL
    Crossover pipe has to have a flex if its using a vband on both sides as this is what allows the pipe to slide in and be pulled tight. If it can't do this then your essentially torquing the manifolds off the head to close the gap. If you don't have a flex in the crossover, the design is flawed as you'd have to have the crossover pipe perfect and thats assuming the SSAC ARE AN EXACT COPY which we all know is not true.
  20. #20 Re: header interest important!!
    Feb 2009
    Quote Originally Posted by JJ91284 View Post
    First, the crossover isnt going to be dual vband. Its gonna have a v band at the rear and retain the donut flange seal as i have seen now problem with the sealing capabilities. Second, each unit is mocked up on the engine to ensure fitment, so that wont be an issue.
  1. Important: ZZP Retainer Issues
    By BillBoost37 in forum General Tech Discussion
    Last Post: 04-04-2012, 10:29 AM
  2. Important information about your tires...
    By Keet04GTP in forum Off Topic Discussion
    Last Post: 08-20-2008, 08:56 PM
  3. Important Safety Notice
    By stugots in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2008, 11:33 AM
  4. Few Important Questions
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-31-2008, 08:03 PM
  5. important all l67 owners read.
    By bad1999gtp in forum Off Topic Discussion
    Last Post: 03-13-2008, 03:41 PM
