Thread: #4 cylinder misfire
Results 1 to 8 of 8
  1. #1 #4 cylinder misfire
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    Well check engine light came on again and thats what poped up. Checked wire and its good so its plug or coil. Question is ... what plug would ya'll recomend? only mods are CAI and no u bend or cat. Thinking maybe a colder range plug? been browsing on here just checking but any info would help. thanks
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  2. #2 Re: #4 cylinder misfire
    SE Level Member DerekD's Avatar
    Indianapolis
    I would use stock plugs.
  3. #3 Re: #4 cylinder misfire
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by JCG's-GTP View Post
    how did you test the wire?
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  4. #4 Re: #4 cylinder misfire
    Feb 2008
    Nashville
    I didn't. My wife was driving the car when it came on and took it to a family friend who scaned car. She said he tested wire and that it was ok. So I'm going by his word.
  5. #5 Re: #4 cylinder misfire
    St Louis MO
    I was only asking because a VOM cant check impedance or arching under load. Perhaps he swapped wires, coil packs, etc.
    2010 Camaro SS LS3
  6. #6 Re: #4 cylinder misfire
    Feb 2008
    Nashville
    I'm gonna use her exact quote... lol "he used this pointey thingy and touched it to each wire. he said if wire was bad it would spark" She did say it sounded as if engined speed up as he touched each wire. lol thats what i get for wife driving my car
  7. #7 Re: #4 cylinder misfire
    Oklahoma
    Oh dude, you and I could swap stories on Wife Automotive Diagnosis. I have had similar type explanations, some just boggle the mind.
  8. #8 Re: #4 cylinder misfire
    GTX Level Member kingd44's Avatar
    Feb 2008
    newyork
    my # cylender is misfiring right now too and noboody can figure out y
  1. Misfire like no other
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2008, 10:02 AM
