Thread: LTFT all over
Results 1 to 20 of 22
  1. #1 LTFT all over
    GT Level Member duane9586's Avatar
    Apr 2008
    ny
    I recently put on 1.9 RR's and a ssic. At first I could not get the upper gasket from zzp to seal, after 2 gaskets leaking I finally just made my own gasket and no more leak. With the leaking gaskets my fuel trims were 20+ now that I fixed it my FT are all over. At idle they can go up to 14 and at wot they are + or - around 2. I have sprayed tb cleaner all over the engine and can't find any vacuum leaks anywhere. I took it to nyc last Friday and while in stop and go traffic the car would surge when I would just lightly touch the gas and sometimes it would stall. I have not been able to get it to do it again but it was pretty regular that day. Can adding the ssic and rockers change my trims that much or do you think I have another problem???? Thanks for any input.
    Here is a scan http://www.scandepot.net/viewscan.php?pk=4912
    180*, Overkill, K&N, MSD, GEN V, AL 104's,ZZP Shift kit,SD Headers,1.9rr's, 90#,3.2zzp,0KR, 8K HID,Was a Base Model
  2. #2 Re: LTFT all over
    May 2008
    staten island,NY
    definitely a vacuum leak, i wouldnt use the ZZP gaskets, been there done that. i made my own with RTV. also check and make sure that the intercooler plates are not warped, that will also make it not seal and risk running a cylinder lean
  3. #3 Re: LTFT all over
    Apr 2008
    ny
    I am not using zzp anymore I made my own gasket and that area is not leaking anymore. I sprayed around the whole IC with tb cleaner and there was no change in the way the car idled. You did the whole gasket area with RTV and it works??
  4. #4 Re: LTFT all over
    May 2008
    staten island,NY
    i didnt use gaskets i used rtv, you do have a leak because the car is stalling and dieing and your LTFT is 14....vac leak...something is leaking somewhere. like i said make sure your plate is completely flat
  5. #5 Re: LTFT all over
    Apr 2008
    ny
    i know i have a leak i just have no idea where
  6. #6 Re: LTFT all over
  7. #7 Re: LTFT all over
    Apr 2008
    ny
    did that still can't find it
  8. #8 Re: LTFT all over
    Joliet, IL
    Quote Originally Posted by duane9586 View Post
    if you deleted your egr check the plate on the lim.....thats where mine was i just made a silicone gasket and didnt cut the 3 egr holes in it no more vac leak....i kept the block plate on anyway tho....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  9. #9 Re: LTFT all over
  10. #10 Re: LTFT all over
    I say warped core since you got a sh!tty SSIC
  11. #11 Re: LTFT all over
    May 2008
    staten island,NY
    do a smoke test
  12. #12 Re: LTFT all over
    Apr 2008
    ny
    My IAC count is under 50 also. For the smoke test do I pull smoke through the TB or do it another way?
  13. #13 Re: LTFT all over
    May 2008
    staten island,NY
    you need a smoke machine, it uses baby oil and you hook up an airline to it,then it plugs into a vacuum line..most performance shops should have one...what you can do is go to home depot and buy one of those big rubber drain caps that will fit over the TB and clamp down, drill and tap an air fitting into the centre of it and put 10psi into it and hear from where it is leaking from. my guess is your core is warped, happened to me
  14. #14 Re: LTFT all over
    Apr 2008
    ny
    thanks I have a smoke machine so i will try that.
  15. #15 Re: LTFT all over
    Apr 2008
    ny
    I put air into the engine and it was leaking out the oil dipstick tube. Right where the o-ring is on the dipstick the plastic was broke so I wrapped it with electrical tape for now untill I can get a new one. My FT is now between 3-6 which is better then 16.4
  16. #16 Re: LTFT all over
    Banned - Busted For Scamming
    Feb 2009
    Well youre pulling more air with those rockers now so im gonna say that might be normal. How does the car run? Its normal for air to leak outa the crankcase, leakage past the rings is normal to some extent, a proper test would be cylinder leakdown test.
  17. #17 Re: LTFT all over
    Apr 2008
    ny
    the car runs great now, no more surging or stalling. Now I just need to play with the pt and try to get the FT back by 0
  18. #18 Re: LTFT all over
    Feb 2008
    So, it just ended up being a leak past the oil dipstick?
  19. #19 Re: LTFT all over
    Feb 2009
    Well my core works... yay!! lol
  20. #20 Re: LTFT all over
    Apr 2008
    ny
    yup just the oil dipstick. The ssic never had a leak for some reason all of the gaskets that zzp sold me did not have any gasket material where it was leaking. I made my own gasket and it worked great.
  1. ltft +12 help
    By DOUGLASMELTER in forum PCM Tuning
    Last Post: 10-22-2009, 06:39 AM
  2. Lean LTFT!
    By Lumpo in forum PCM Tuning
    Last Post: 09-25-2009, 11:17 PM
  3. LTFT issue cured
    By cn1151 in forum General Tech Discussion
    Last Post: 09-23-2009, 10:05 AM
  4. Vac leak LTFT?
    By Sabrewings in forum PCM Tuning
    Last Post: 04-15-2009, 05:42 PM
  5. Why LTFT, when STFT should be quicker
    By IndeedSS in forum PCM Tuning
    Last Post: 08-26-2008, 08:27 AM
