Thread: Exhaust Glowing Red!!!!
Results 1 to 14 of 14
  1. #1 Exhaust Glowing Red!!!!
    Canada
    My exhaust manifold and down pipe are glowing red hot and you can smell the metal like its burning... Is this the problem of a bad CAT??? My car has been stuttering at high RPM or whenever the SC kicks in for awhile....Oh also does anyone know what these cars are like with no Cat??? Loud?? Too Loud??
    Any Ideas??? Thanks in advance
  2. #2 Re: Exhaust Glowing Red!!!!
    Texas
    Sounds like the Cat to me.
  3. #3 Re: Exhaust Glowing Red!!!!
    Charles City, IA
    You done gone and have got a clogged cat son. Get a down pipe or some headers now.
    SMGPFC Two Nipple General
  4. #4 Re: Exhaust Glowing Red!!!!
    SE Level Member GTPcoupe's Avatar
    Feb 2010
    Canada
    Definitly sounds like a clogged cat. Replace it, or go even better with headers or just a 3" downpipe with high flow cat. You'd probably notice a huge difference the second you touch the gas pedal if the one you have now is that bad.
    '99 GTP coupe - Growing mod list/summer car
    '98 GTP Sedan - Winter ride, 315,000+kms and going strong!
  5. #5 Re: Exhaust Glowing Red!!!!
    Canada
    Any suggestions on where I should get it/good prices, what exactly I should get if Im gonna do a 3" down pipe and high flow cat ???
  6. #6 Re: Exhaust Glowing Red!!!!
    Ummm, get the downpipe if you get the downpipe?
    zzperformance. 3" with a high flow cat...it all bolts in like factory. done.
  7. #7 Re: Exhaust Glowing Red!!!!
    Canada
    also if I put a 3" downpipe on with a high flow cat will I have to change any of the other exhaust pieces
  8. #8 Re: Exhaust Glowing Red!!!!
    Nov 2009
    Grand haven
    read what blue said!!! ^^^^
  9. #9 Re: Exhaust Glowing Red!!!!
    GT Level Member chickenfried's Avatar
    Feb 2010
    Gilman IA
    i have heard that the u-bend delete is a must. will be doing that soon.
  10. #10 Re: Exhaust Glowing Red!!!!
    Feb 2010
    Canada
    Get a stainless steel down pipe from zzp
  11. #11 Re: Exhaust Glowing Red!!!!
    Oct 2008
    Northern Illinois
    ZZ Performance
    There. Under model select 3" Bolt-In W/Cat
  12. #12 Re: Exhaust Glowing Red!!!!
    Canada
    Ya I was looking at em last night thanks for all the info guys, just one last question....Bwolf is it even worth it to go with the 304 or is it a waste of money, might be a stupid question but they say it can somewhat improve performance????
  13. #13 Re: Exhaust Glowing Red!!!!
    the stainless will just last longer, but honestly even the mild steel should outlast how long you have your car.
  14. #14 Re: Exhaust Glowing Red!!!!
    Oct 2008
    Northern Illinois
    Quote Originally Posted by 1000PRIX View Post
    Nope it won't improve performance and as bio said the normal downpipe will most likely outlive the car.
  1. Glowing manifolds, what could be the cause?
    By Blue Rebel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-04-2010, 12:29 PM
  2. 93 grandprix Catalytic converter glowing
    By ronaldgtp in forum General Tech Discussion
    Last Post: 11-21-2009, 11:57 AM
  3. VRS EXHAUST- Mandrel Exhaust kit.
    By Lion29GTP in forum General Tech Discussion
    Last Post: 03-18-2009, 02:47 AM
  4. VRS EXHAUST- Mandrel Exhaust kit.
    By Lion29GTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2009, 02:43 AM
