Thread: slight wetness in exhaust, no smoke, no overheating, what is it?
Results 1 to 6 of 6
  1. #1 slight wetness in exhaust, no smoke, no overheating, what is it?
    AZ
    So I still actualy have yet to replace the EGR on 2000 GTP, I posted here a couple weeks ago, then I got really sick and havent been able to attend to anything. So, I still have an SES light on throwing P401 but also, I believe i am getting a little coolant out the exhaust, not enough to be dripping or anything, but enough to make the tips appear moist, and I am sure its not oil, because it, effectively "drys up" the other thing is the car never has overheated at all, and does not ever smoke at all, not on idle, not while driving.....Could this at all be part of the EGR issue, or do I need to dig deeper?
  2. #2 Re: slight wetness in exhaust, no smoke, no overheating, what is it?
    AZ
    also, the oil has no coolant in it...
  3. #3 Re: slight wetness in exhaust, no smoke, no overheating, what is it?
    Charles City, IA
    You sure it is coolant or is it just condensation from the heat of the exhaust. Also the cat will produce water.
    SMGPFC Two Nipple General
  4. #4 Re: slight wetness in exhaust, no smoke, no overheating, what is it?
    AZ
    I am actually not sure to be honest......my resovoir is a little gunky and the coolant in there was pretty nasty, but not really like oil, more like old dex cool and stop leak....I am thinking a oolant flush is in order to start...is there possibility the head gasket is failing and letting oil in the water, but no water in the oil?
  5. #5 Re: slight wetness in exhaust, no smoke, no overheating, what is it?
    SE Level Member PH04GTP's Avatar
    Janesville, WI
    If it just evaporates its water. One of the many byproducts of an internal combustion engine.
  6. #6 Re: slight wetness in exhaust, no smoke, no overheating, what is it?
    AZ
    so after chilling out and talking to a couple peeps, I dont think i have a major issue, and need to get the EGR taken care of first, going to attempt to clean it tomorrow.....does the electrical connection on top of the egr just pull out or does it have clips or something? I dont want to just go yanking on it...
  1. Power loss / slight stumble @ WOT
    By Wilford in forum General Tech Discussion
    Last Post: 10-25-2009, 08:05 AM
  2. Blue smoke out exhaust
    By SilverGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 10:16 AM
  3. overheating
    By famouspork in forum General Tech Discussion
    Last Post: 05-27-2009, 09:22 AM
  4. HELP!! overheating
    By sciontc1011 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:55 PM
  5. overheating
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-09-2008, 10:18 PM
