Thread: help vibration
Results 1 to 13 of 13
  1. #1 help vibration
    SE Level Member shawnheck03gtp's Avatar
    Billings, MT
    So i have a 2003 gp gtp motor has 19,000mi. and the tranny has 10,000mi. on them. I have a bad vibration under moderate to hard engine loads. It feels like the motor is on the firewall and you can also hear it. i am worried i checked all the motor mounts they are good and i power braked it and the motor moves like two inches. please help to keep me from pulling out my hair.
  2. #2 Re: help vibration
    im oh so glad that you didnt say at all what you have done to your car, how caught up you are on maintenance, etc. it helps us out a lot.
  3. #3 Re: help vibration
    Billings, MT
    i have a fwi, u bend delete custom cat back
  4. #4 Re: help vibration
    Billings, MT
    oh and did all the maint. 5000 mi. ago plugs, wires, fuel filter, fuel pump, tranny service, wheel bearings was what i thought it was , struts.
  5. #5 Re: help vibration
    Sure the mounts aren't bad...pretty easy to miss it since they are filled with fluid...one might have leaked out. That...and you could try checking the dog bone mounts too to see if they cracked or rotted...just a thought.
  6. #6 Re: help vibration
    Billings, MT
    the dogdones are good they didnt have any cracks
  7. #7 Re: help vibration
    its hard to say without actually being there. what exactly is it doing?
  8. #8 Re: help vibration
    Billings, MT
    if you turn it gets worse and it does it anytime your in the gas more than 50%
  9. #9 Re: help vibration
  10. #10 Re: help vibration
    Billings, MT
    i checked the axles and one was bent dont know how. so i replaced that and the wheel bearings cus i made the ebay mistake and they lasted 6 months and were grinding. But now i have a awsome job so i am going to do the other axle and mounts to see if that fixes it. if not im throwing parts at it cus the body does have 140,000.
  11. #11 Re: help vibration
    SE Level Member DaL's Avatar
    Not sure how long you've been having the problems..
    Obviously work was done with the engine and trans, just wondering if you checked the mounts underneath. If you have been having problems since you worked on it, you might want to look around where you were working, check the lower mounts and trans mount.
  12. #12 Re: help vibration
    Billings, MT
    yea thats the only thing i havent checked yet. and the dealer did the work and put a crate engine in after the 3 used engines the warantee company bought that either spun a rod bearing or sent them thru the block. yea i wasent happy to pay for my car for 3 months and it be in the shop. sorry touchy subject but soon i will really find out cus im buying a computer, pulley, cam, headers. and im doing it just to piss off all the ricers in town and in the only one in town with a modded gp and everyone talks crap and says they cant be fast.
  13. #13 Re: help vibration
    Jul 2008
    sumter,south carolina
    stock GTP will rape any rice in town where im at.
    02 GTP with mods 05 GP for DD
  1. bad vibration under wot
    By shawnheck03gtp in forum General Tech Discussion
    Last Post: 10-08-2009, 09:03 PM
  2. Odd Vibration
    By VGPGT in forum General Tech Discussion
    Last Post: 04-15-2009, 04:18 PM
  3. vibration
    By david hagaman in forum General Tech Discussion
    Last Post: 04-11-2009, 11:16 AM
  4. Vibration
    By silvertip in forum General Tech Discussion
    Last Post: 04-09-2009, 09:09 AM
  5. vibration
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2008, 05:24 AM
