Thread: Intercooler radiator
Results 1 to 16 of 16
  1. #1 Intercooler radiator
    Ossian, IN
    Well in September I put on an SSIC, and it was working great and all but I ended up buying a Stage 2 zzp core to go with the rest of the new build. Is it pretty necessary to go to a larger fmhe? Any input/advice?
    Thanks
  2. #2 Re: Intercooler radiator
    it will help with the cooling, but not necessary as much if you dont constantly beat on your ride. it helps out a lot with heat soak from multiple runs.
  3. #3 Re: Intercooler radiator
    Ossian, IN
    Well it's not driven often, at all. Almost two months since I have driven it. Just making sure that if i spend all of this money on an ic, its going to do its job. Just curious as to what others are using on their setups.
  4. #4 Re: Intercooler radiator
    im about to pick up an ssic with a st2 fmhe, but i doubt ill have it on in time to be any help for you. but the st2 is a good step up from the st1.
  5. #5 Re: Intercooler radiator
    Moore, Oklahoma
    If you want good looks and strong fins, the PRJ rad is the way to go, I love mine...
    No cutting up the hood latch or anything else required, its truely a bolt on item...
    Shawn W. Larsen
  6. #6 Re: Intercooler radiator
    Ossian, IN
    I didn't see that on prj's site. Is there anywhere else to get it?
  7. #7 Re: Intercooler radiator
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I'm stunned. You are right it is no longer listed on his site.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  8. #8 Re: Intercooler radiator
    Ossian, IN
    Anybody know what the PRJ one runs? Similar to the price of some of the ZZP i/c radiators? Would like to get that PRJ one, if anyone can find if they are sold elsewhere or specs I would appreciate it.
  9. #9 Re: Intercooler radiator
    St Louis MO
    Quote Originally Posted by silvermistGT View Post
    iirc it was $400+ and if it's not on his website, you may want to email him about one.
    2010 Camaro SS LS3
  10. #10 Re: Intercooler radiator
    SE Level Member TheRealKoop's Avatar
    Lima, Oh
    I use the zzp #4 radiator, fits great right where the AC condenser is supposed to be. Bad shot but heres a pic:
    97' GTP- HAI| 160| N*| Ported Blower| 2.55"|
    S2 ZZp IC| LIM| Heads| 50#| XP| Pacesetters| Flow40's
    AL 103| S2 Volt Booster| Alt rewire| FP rewire.
    Built Tranny| Poly Mounts| 3.69's| 3000 stall.
    Walbro 255|AEM WB| Powertuner.
  11. #11 Re: Intercooler radiator
    Elk Grove Village, IL
    If you upgrade your core, it would be wise/most noticable to upgrade everything. Bigger lines, better pump, bigger FMHE. A local went from an SSIC to a S2 IC and noticed very little gain since he left everything from the SSIC installed and just used the S2 core.
    Here is the FMHE I will be using. A few people on clubgp have made it fit without removing the A/C and from what I hear I will have an easier time since there is more room in Regals to work with.
    eBay Motors: VW GOLF JETTA SCIROCCO RADIATOR 84-92 ALUMINUM CORE NEW (item 250222363581 end time Mar-11-08 13:48:40 PDT)
  12. #12 Re: Intercooler radiator
    Lima, Oh
    Apparently thats exactly what zzp uses as a #2 FMHE.
  13. #13 Re: Intercooler radiator
    Quote Originally Posted by TheRealKoop View Post
    What?? Did you even see the dimentions and sizes?? Overall and core? Those meet #4s numbers.
    Radiator 2 is standard for our Stage 2 intercooler kits. It has a 20.6x12.7x1.3” inch core. Overall measurements are 24.25x13x2. It is rated at 65,400 BTU, has a fluid capacity of .37 gallons and a dry weight of 4.25 pounds. This is the minimum size you should consider for a full size intercooler kit.
    Radiator 4 is what we run in our record setting GTP. It is too large to fit in the normal install location. It is recommended for hard core builds, where the AC condenser has been removed and this unit can be installed in that location. It has a 26.6x12.7x1.3” inch core. Overall measurements are 30.25x13x2. It is rated at 84,500 BTU, has a fluid capacity of .46 gallons and a dry weight of 5.5 pounds
    IT MEASURES 13 INCHES TALL, 30.5 INCHES WIDE, 2 INCHES THICK, AND THE PLASTIC TANKS ARE 1 3/4 INCHES WIDE MAKING THE CORE 26.5 INCHES WIDE
  14. #14 Re: Intercooler radiator
    Ossian, IN
    Well I guess I just need to make a decision then on what to buy. Radiator and lines will be an easy decision, I just need to figure out if the Flojet will be enough. Thanks for the good info and opinions.
    Edit: I heard that about the VW radiator as well, but it definitely is more along the lines of the zzp stg 4.
  15. #15 Re: Intercooler radiator
    Lima, Oh
    Ah good call. Yeah i meant #4 i don't know wtf i was thinking. measurements ftw.
  16. #16 Re: Intercooler radiator
    Hehe, I was like ???
  1. Short Stack Intercooler [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-30-2012, 04:20 PM
  2. Intercooler Flow???
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2008, 08:45 PM
  3. If you recently bought an aftermarket radiator from ZZP or W-Body store
    By Gandalf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2008, 11:06 AM
  4. Transmission lines to radiator
    By SyntheticShield in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2008, 10:45 PM
  5. Intercooler Spray Bar Kit...
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 12:18 AM
