Thread: vent soleniod and gas cap removal?
Results 1 to 5 of 5
  1. #1 vent soleniod and gas cap removal?
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    wow...you all should see what a sticking fuel pressure regulator can do to fuel trims....that was a crazy couple days of problem solving. in trying to find the problem ive found just how hard the fuel pumps work< even with the vent soleniod open > at different levels of the tank being full. in seeing the pump work harder at different times i decided pump life would be greatly increased with the removal of the vent soleniod and with a small whole in the gas cap. anyone ever try this before and does it work?
  2. #2 Re: vent soleniod and gas cap removal?
    Apr 2009
    ERIE
    come on now.....someone has got to have tried this before... hell hook up a dc amp meter to your power wire to your fuel pump at full tank, empty, and with cap off and you will see a huge difference. anyone?
  3. #3 Re: vent soleniod and gas cap removal?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I guess I already did something similar, but not for the reasons your talking about, so I can't comment about any differences or anything.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: vent soleniod and gas cap removal?
    Apr 2009
    ERIE
    Quote Originally Posted by Scimmia View Post
    how did you do it and why? did you do it the same way im thinking of or differently?
  5. #5 Re: vent soleniod and gas cap removal?
    QCA, IA
    I have dealt with EVAP problems on far too many cars, so when I had my tank out a while back, I just decided to get rid of the system. Call it preventative maintenance.
    I removed the charcoal canister, and spliced the lines going into it and coming out of it together. This gave me a straight shot from the tank vent up to the vent canister. I then removed the canister and replaced it with a breather filter, although I don't think that's necessary. If you just unplug the solenoid, it should stay open and the canister would act the same as my breather filter.
  1. down the vent
    By echarleswhyte in forum General Tech Discussion
    Last Post: 09-21-2009, 06:46 PM
  2. Air vent issues
    By Draygyen in forum General Tech Discussion
    Last Post: 01-28-2009, 11:58 AM
  3. vent mount
    By gotboost3 in forum Visual/Body Modifications
    Last Post: 12-05-2008, 05:59 PM
  4. just need to vent here, any 2 cents is welcome!!
    By fabz77gp in forum Off Topic Discussion
    Last Post: 07-22-2008, 01:35 PM
  5. i have the need to vent
    By stlmo_gtp in forum The Rant Forum
    Last Post: 04-09-2008, 10:03 AM
