Thread: a good cam for the 3.0 or 2.8 pulley
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
  1. #21 Re: a good cam for the 3.0 or 2.8 pulley
    GT Level Member tylerbinski's Avatar
    Canada
    Check out the XP-Z cam
    I got the XP, and think I should have got a larger cam...
    ALSO!!! don't forget to turn down / machine your blower snout so you can run sub 2.8" pulleys..
    I forgot while blower was off the car..
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  2. #22 Re: a good cam for the 3.0 or 2.8 pulley
    XPZ is only if youre looking for a decent cam to make decent times. i wouldnt recommend it to anyone unless they were actually going for a setup like that. i think its a small, wimpy cam for being one of the bigger cams.
  3. #23 Re: a good cam for the 3.0 or 2.8 pulley
    Donating Users blowfishRus6's Avatar
    g.a.
    bio what is your idea of a cam, what do you expect out of it???
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  4. #24 Re: a good cam for the 3.0 or 2.8 pulley
    ^^^ Im wondering the same thing...appearently we all know nothing and he knows everything when it comes to cams...
  5. #25 Re: a good cam for the 3.0 or 2.8 pulley
    for the OP in this thread, an s1x or XP would work great. hell, even a VS would be a good choice.
    for me the only cams id ever run were a NIC, IS3, TEP, or something custom from PRJ. i like BIG cams with BIG idles, but thats just my preference. i never really wanted my car to be obscenely fast, but i wanted it to sound cool and haul some ass when i wanted to. a cam choice is a VERY crucial aspect to a build and i think people are taking it way too lightly on thinking that just any cam off the shelf will get them to a certain level of power which is completely untrue. i know a few guys with VS cams (made to run on stock heads with stock valve springs [ie, small cam]) and their cars would blow a few of the guys with big cams out of the water.
    its all in what you want to do with it. you cant just suggest an XP to everyone and it be a good suggestion. im not a ZZP leghumper by any means, but they do make some good products. i just think there are other choices out there that most people just dont consider because they dont know any better.
  6. #26 Re: a good cam for the 3.0 or 2.8 pulley
    g.a.
    i dont give a **** how it sounds i just want it to be fast and a decent powerband
    its slow.
  7. #27 Re: a good cam for the 3.0 or 2.8 pulley
    SE Level Member bigdawg15005's Avatar
    pittsburgh,pa
    FWIW i totaly understand and agree with this quote....all of it...do the research for what your trying to get out of your car. Do you want it to be fast as hell and guzzle gas, or fast and good on gas ect. Thats what determines what cam and other parts to go with it you should get. Anymore now days everyone gets lazy and just goes wit the majority of what everyone else says is the best...It took me bout two months to decide on a cam bc of all the research on everything i was doing along with it.Bc i want it to sound good ,be fast,and get half decent gas milage. Im glad i took my time so that later on i wouldnt be doing it again bc it didnt work with this part or that one ect,or this one would have worked better for my setup u know. plus all the xtra money you will spend trying somthing else.Just my .02
  8. #28 Re: a good cam for the 3.0 or 2.8 pulley
    finally someone sees my point. all of the cams out there are VERY different from one another in powerband, fuel economy, idle, tunability, necessary supporting mods, etc.
    you need to do research and figure out which one is good for YOU, not take suggestions completely to heart from everyone else.
  9. #29 Re: a good cam for the 3.0 or 2.8 pulley
    Who the hell needs a cam anyways...fuggin noobs.
  10. #30 Re: a good cam for the 3.0 or 2.8 pulley
    g.a.
    ron regal dont to hit 11's
    its slow.
  11. #31 Re: a good cam for the 3.0 or 2.8 pulley
    Ron Vogel
  12. #32 Re: a good cam for the 3.0 or 2.8 pulley
    g.a.
    whatever..
    its slow.
  13. #33 Re: a good cam for the 3.0 or 2.8 pulley
    Quote Originally Posted by blowfishRus6 View Post
    whatever..
    LOL
  14. #34 Re: a good cam for the 3.0 or 2.8 pulley
    g.a.
    i lol'ed too
    you have a pm sir
    its slow.
  15. #35 Re: a good cam for the 3.0 or 2.8 pulley
    Jan 2009
    Michigan
    s1x is a nice cam. someone correct me if im wrong, but arent the rocker ratio's in 2000+ actually 1.66 vs. 1.6? if so, then the cam specs advertised will be SLIGHTLY higher, since they list them for 1.6 rockers. something to keep in mind when using stock heads. again, correct me if im wrong.
  16. #36 Re: a good cam for the 3.0 or 2.8 pulley
  17. #37 Re: a good cam for the 3.0 or 2.8 pulley
    Meh...prove it
  18. #38 Re: a good cam for the 3.0 or 2.8 pulley
    SE Level Member 00obgtp's Avatar
    IA
    Those runs are pretty horrible for my mods. I need to figure out what is wrong in my tune or where I am getting a hot spot for knock. Where are you at in IA?
    im from tama but live in waterloo
  19. #39 Re: a good cam for the 3.0 or 2.8 pulley
    IA
    alright thanks everyone ill just do rockers ic pulley tune etc and see where that gets me without a cam
  1. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  2. Track Pulley Good Question!!
    By BLACKEDOUTGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-26-2008, 06:14 PM
