Thread: Help with SES codes
Results 1 to 7 of 7
  1. #1 Help with SES codes
    My 3.8 SC on a 2000 GTP has random misfiring. Seems to be when under a load or at a constant speed. Code P0352- knock sensor, code P1361 Ing. Control Circuit Low Voltage, and P1362 Ing. Bypass Circuit. Replaced Ing. Control Mod about six months ago, plugs and wires 2 weeks ago. Check resitance on coil packs, both primary and secondary, check out within specs. All vacum lines seem to be in good condition. Anyone with ideals on what the issues may be.
  2. #2 Re: Help with SES codes
    Charles City, IA
    Make sure the ground for the icm is good.
    SMGPFC Two Nipple General
  3. #3 Re: Help with SES codes
    Thanks, I'll check that out.
  4. #4 Re: Help with SES codes
    Plugs and wires good?
  5. #5 Re: Help with SES codes
    Plugs ans wires are new. Check ground leads, they are ok.
  6. #6 Re: Help with SES codes
    Ok, look your codes up at Gearchatter.com They have the FSM pages for the codes on the site. The diagnostic aids and the diagnostic charts may lead you to things we haven't thought of, since the info was put together by the engineers that developed the systems.
  1. how to get codes
    By bowtechguy in forum General Tech Discussion
    Last Post: 04-16-2009, 05:19 PM
  2. Have some codes need help
    By pDuB257 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2009, 03:25 PM
  3. 3 codes, what could it be?
    By spidamanSS in forum General Tech Discussion
    Last Post: 08-19-2008, 02:24 AM
  4. I got some codes
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2008, 07:41 AM
  5. ecu codes ??
    By sal3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2008, 12:48 PM
