Thread: 2000 grand prix gtp motor
Results 1 to 4 of 4
  1. #1 2000 grand prix gtp motor
    Ohio
    Will this work in a 1997 gtp? any mods?
  2. #2 Re: 2000 grand prix gtp motor
    Nov 2008
    Searcy,Arkansas
    Sorry..Tried to answer you. The 97-03 is the 6th Gen Grand Prix. The only difference is the SE was 3.1 if the 97 was a GTP then it should fit since they had the SAME motor. And then again even if it was a base 97 it still should fit.
  3. #3 Re: 2000 grand prix gtp motor
    Wausau, WI
    Yes it will work, they are the same motor.
  4. #4 Re: 2000 grand prix gtp motor
    It will as long as your not dealing with the PCM...its fine.
  1. 2000 pontiac grand prix
    By exfirefighter 1511 in forum Introductions/Noob Questions
    Last Post: 07-19-2009, 10:42 PM
  2. 2000 Grand Prix GT (Vincenz)
    By GrandPrixGT00 in forum Visual/Body Modifications
    Last Post: 07-17-2009, 12:10 AM
  3. 2000 grand prix headlamps
    By offroadfury6 in forum Visual/Body Modifications
    Last Post: 04-16-2009, 10:35 PM
  4. 2000 grand prix gt
    By candt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-01-2008, 10:41 AM
  5. 2000 Pontiac Grand Prix GT
    By 2000grandprixGT in forum Introductions/Noob Questions
    Last Post: 03-18-2008, 08:23 PM
