Changing the supercharger oil before I put it on and I heard 10w 30 synthetic will work fine. Is this ok?
never heard that before. i always use genuine gm supercharger oil. i would be curious to know if that is ok to do though because that would certainly be a bit cheaper
No it will not work the same. The supercharge oil is pretty much a high speed gear oil. Just use the right stuff and be done with it. GM supercharger oil that is.
No, that is not okay. What is okay though is getting high temp gear oil from the part store. Same stuff.
Well I know a few people that have been running 10w 30 full synthetic in the superchargers for almost a couple years now and haven't had any issues. I've heard it actually works better than the gm s/c oil. Idk, I'm gunna try it, I'll let youguys know what happens.
i did that![]()
Well my gm supercharger oil has worked for 150,000 miles so I am going to stick with that.
GM S/C oil.
That's it.
Nothing else.
Interesting thread. I've been contemplating this for a while, i.e.:is GM S/C oil?
I Googled. I found an old thread at sccoa.com where the Ford turds were talking about the M112/Eaton oil. Thread Link
It seems that S/C oil is basically a 5w-20 that takes longer to oxidize or vaporize. But primarily, is has low Thermal characteristics. IOW, it doesn't expand or contract with temperature. So, that rules out Mobil 1.
Hmm..Turbine oil. If it works in a F-22, I think it'll be o.k. for a Pontiac :-P
The Oil store 16 bucks a quart, or available at you local airport![]()
lmao nice f22 lol
Really? I heard GM S/C oil was something crazy like Something W 80..
Supercharger = Gears.
Gears = Oil
I used gear oil and if someone has anything to say about it i pose this question... Why would gear oil not be sufficient? It its meant for the crazy stress and high speed of a differential, and the only thing different about that and the m90 gears is that 1. Gears are smaller, not sure on speed might actually be slower. 2. Actually have alot less to no stress on them, especially when most driving is at cruise. Ive had no problems using gear oil and upon removal/ dissasembly found no evidence of wear. But if it makes you feel better, use the GM S/C oil.
