Thread: Jerking and white smoke
Results 1 to 8 of 8
  1. #1 Jerking and white smoke
    St Marys PA
    i have a 99 gtp...today i was driving and noticed that the car started to jerk...it seemed like when i stopped and then accelerated it felt like it was stalling but then once it got going it went away and would happen every stop and go...the servece engine light came one when i parked it and smoke came out from under the hood...i went out an hour later and started it up abd left it idle,,tons of white smoke came from the exaust pipes....any one have any ideas what happend...only mode of transportation? help would be greatly appreciated
  2. #2 Re: Jerking and white smoke
    MO
    wrong section, no one will find that in here...
    <brandonl2000> LMAO D!!
  3. #3 Re: Jerking and white smoke
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    just reading your post seems like the engine overheated and may have done damage to the heads or just the head gaskets. i know these cars are known for the lower intake manifold gaskets failing and making coolant go into the cylinders and burnt out the exaust. what did the service engine soon code turn out to be? did you notice if the temp guage was high? or low coolant light come on?
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  4. #4 Re: Jerking and white smoke
    Nov 2008
    norman oklahoma
    lim gasket failing get it fixed before hydrolock
  5. #5 Re: Jerking and white smoke
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    My oil looked like mustard when i changed it after doing my lim gaskets, i dont think thats a good thinG. Lol. Its all good now tho.
  6. #6 Re: Jerking and white smoke
    SE Level Member PowerStroker's Avatar
    Minnesota, Eh?
    When we blew the "Cash for Clunkers" up at work they billowed white smoke. Check your oil. Don't goto a shop saying "I need new LIM gasket." You'll pay out the anus and it might not even be that... Working at a shop, I HATE HATE HATE people that come in and tell me, a technician, what's wrong... They'll charge you for that and whatever else might be wrong.
    Start with the basics and work from there. Check your fluid levels...
    2003 F-350 7.3L Powerstroke, hybrid (burns diesel and rubber ), lots of mods, and gets 22.5 mpg!
    2000 Grand Prix SE 3.1L
  7. #7 Re: Jerking and white smoke
    Quote Originally Posted by PowerStroker View Post
    The only time you should be telling people whats wrong is if you're just buying parts.
    I would think suggesting checking a part you THINK is gone wouldn't be above and beyond acceptable correct?
  8. #8 Re: Jerking and white smoke
    St. Louis Mo.
    Moved to correct section.
    James Shafer
    St. Louis MO
  1. running lean or rich + white smoke on idle
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 08:51 PM
  2. White smoke problem
    By SilverGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 10:24 AM
  3. SES light/White smoke
    By fudhimself in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2009, 10:30 PM
  4. Replacing Blower Motor---Puff of white smoke
    By Burgundyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2009, 07:36 PM
  5. Replacing Blower Motor---Puff of white smoke
    By Burgundyman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-08-2009, 06:46 AM
