Thread: Need help
Results 1 to 8 of 8
  1. #1 Need help
    SE Level Member 04GTP956's Avatar
    RioGrandeValley
    Im going to make the fwi for my car but i was looking at the cone filters that k&n sells know im going to put one on that has a 3in inlet but i dont know which cone to choose because of all the cone sizes that they offer, do any of you know what cone size would fit inside the fender well, or if u have a part number that would fit?
  2. #2 Re: Need help
    RioGrandeValley
    Anybody????? I thought this was the place where i could get awnsers what happened, does anybody have this mod on ther cars?
  3. #3 Re: Need help
    SE Level Member Planeboy18's Avatar
    Cleveland Ohio
    I'm not quite sure of the part number for K&N, but I've always just used Spectre air filters that they have at autozone, advanced auto parts, pepboys. They are about half the price, but they only come in 3 sizes, however, each filter came accomodate 3, 3.5, and 4 inch piping. Just a thought. I used to have a K&N cone on my GTI, but changed it with a Specte and haven't noticed anything bad about it. I've also put spectre filters on an Impala and a GP and IMO they sound a little better than K&N's, but that's just me. Sorry for not really helping you on your original quesiton.
    04 GP GT (1st car now my G-Ma's):
    97 GP GT (GF's): "Project Pink Power"
    00 VW GTI VR6 (15*V6): Slow and Low, That is the Tempo
    91 VW GTI 8v: Big Plans
  4. #4 Re: Need help
    RioGrandeValley
    If i buy the ones that they sell at autozone like u say, how do u clean the filter? Sorry about this question just want to make sure that i wont have to keep buying a new filter everytime it gets dirty
  5. #5 Re: Need help
    Cleveland Ohio
    What I do is just use the K&N filter element cleaner (ironic). But the spectre ones are washable just like the K&N ones but I prefer to use the K&N cleaner and oil souling becuase I had some left over from my old K&N filter (which caused my car to hydrolock by the way, but that was the Ohio monsoon's fault). I clean mine about every 6 months, but filters actually filter air better when they are dirtier and you won't lose air flow since the filter is large enough that all of it's surface area is not an issue. Sort of confusing point there, but basically, the filter is always filtering more air than the car can ever use at one time, so if it is dirty you'll be fine since it's doing a better job cleaning the air. Hope this helps.
  6. #6 Re: Need help
    4" piping and filter or nothing. dont even waste your time with anything less.
  7. #7 Re: Need help
    RioGrandeValley
    are u sure that it wont cause any problems to the car if i go 4"?
  8. #8 Re: Need help
    Cleveland Ohio
    Quote Originally Posted by 04GTP956 View Post
    Not at all. Your rubber intake tube is 4 inch if i'm not mistake. The only one catch I would add to this is that 4in tubing is slightly slower on throttle response but will get you the most top end power.
