Thread: Car "farting out" under boost !?!?!?
Results 1 to 7 of 7
  1. #1 Car "farting out" under boost !?!?!?
    Chi-boogie Ill-noise
    'OO GTP keeps "farting out" whenever I give any type of agressive acelleration. Initially, I thought it was a fuel pressure issue. Since I changed the Cam and crank position sensors the vehicle is running better, and I now see that it only bogs or "farts" under boost. It is as if i can't get the smallest psi of boost before..."FART"! What gives?
  2. #2 Re: Car "farting out" under boost !?!?!?
    Wausau, WI
    any codes when this happens? vacuum leak? plugs? wires? MAF? plugged cat? ICM? do you have something to scan with?
  3. #3 Re: Car "farting out" under boost !?!?!?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Sine it did it before the cam.
    Get new plug wires first (30 bux ones are fine)
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  4. #4 Re: Car "farting out" under boost !?!?!?
    New icm (about 100mi), newer plugs, newer cat(less than 2000mi) I don't have a scanner. It only happens under load (while car is in gear), primarily when attepting to pass, going uphill, even pulling away from a stop light. I can go for the vacuum leaks. I know that there was a fabricated jumble of mess coming from the fitting (vacuum?) extending out of the intake at the base of the SC. I don't know exactly how or what part that is supposed to be there but I created a T to connect two vacuum lines that were taped together in the fabricated jumble of mess and connected it to the intake. Don't know if that was correct, but that's what I did!
  5. #5 Re: Car "farting out" under boost !?!?!?
    Tulsa, Ok
    GO out get a cheap set of plug wires.
    What you are seeing is a classic sign of bad plug wires or even a wire that was not fully on
    98' GS - Sold
  6. #6 Re: Car "farting out" under boost !?!?!?
    muskego
    hehe.... still giddy from this one - had the same problems... after single plug had been squashed, I replaced all plugs with iridium... didn't know any better :P and then it started "farting" under any boost. At my wits end, was told I probably had a vacuum leak. Then sat and had a beer reading this post and said nuts with it - got $30 wires (lifetime warranty), put them in, and oooooh babby!!! =D haven't felt that pull since my last modd =D
    Sorry for doubting, didn't understand that more compression == higher resistance yep, energy was finding an easier ground.
    Cheers,
    Love the forum
  7. #7 Re: Car "farting out" under boost !?!?!?
    Hmmm...Idunno....I will try it. Not like It wont hurt, but I really doubt it.
  1. not making "full" boost
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2009, 03:23 PM
  2. Car "shuttering" under moderate boost?
    By CDoran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 09:25 PM
  3. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
