Thread: MSD Wires
Results 1 to 8 of 8
  1. #1 MSD Wires
    Donating Users PonchoDvr4Lfe's Avatar
    Feb 2008
    Kent, OH
    Does anyone know if the MSD plug wires for the 97-03's will fit on an 2004? I asked PFYC but they had no clue either. Well... this is what they said:
    Hi Mike: We are honestly not sure - the layout of the engine changed somewhat, and the wire length may not be right for the newer engines. It has not been something that I have heard anyone testing, so I could not be sure.
    mandrell@kent.edu wrote:
    > Mike> mandrell@kent.edu
    > None> 2004 Pontiac Gran Prix GTP Comp G
    > 3.8 S/C> ----> Will these wires ""32789: 1997-2003 Pontiac Grand Prix GTP with 3.8L Supercharged V6 (RED wires)"" work on an 2004?
    If anyone knows I'd be much obliged....
  2. #2 Re: MSD Wires
    I live here. UR LOSN's Avatar
    Rockford, IL
    as far as I know they should be basicly the same setup......
    if not MSD does have a custom wire kit...where you make your own wires.
  3. #3 Re: MSD Wires
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Quote Originally Posted by UR LOSN View Post
    This is what I did to get a little longer wire so they aren't forced to be in the way of anything. Plus I know the connections are good and tight!
  4. #4 Re: MSD Wires
    St. Louis Mo.
    I would say they fit for the simple fact that Steve in our club had an 04-05 GTP and he got Kevin's MSD wires he won in Branson. And we put them on at a mod day a few months back and they hooked up without issue.
    I hope that helps
    James Shafer
    St. Louis MO
  5. #5 Re: MSD Wires
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Quote Originally Posted by GeddyLee View Post
    I hope that helps
    Well I wouldn't say w/o issue as my big fat hands and arms kept hitting everything in the engine bay, but hey we got it done w/ no major problems.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  6. #6 Re: MSD Wires
    GT Level Member stkks's Avatar
    Annandale, Virginia
    I just had my MSD coils, wires, and new plugs installed the other day. I know that the information that came with the wires, showed the 3800 Series II in the diagram. I ordered my wires from 3800performance, I hope this helps some. Possibly contact 3800performance, they might be able to answer the 97-03 to 04+ wire question.
    Autopage Alarm w/Remote Start-35% Tint-SPO Tips/Grills-GMPP RTAs-F/R STBs w/Don's brackets-SilverStars H/L Beam-DHP PCM-CORSA-Thrasher CAI-Class II Receiver Hitch-AVS Vent Visors/Tailshades-Chrome Side/Engine Supports-180T-stat-3 AeroForce Gauges-MSD Coils/Wires-NGK TR-55IX
  7. #7 Re: MSD Wires
    Wichita, KS
    Some things did change form the Series II to the Series III motors.
    But what did NOT change was the coil mount, and where the spark plugs are located.
    If you use common since when you install them, they should fit and install without a single problem.
    ~F~
  8. #8 Re: MSD Wires
    Bastard Reptile's Avatar
    Kansas City, MO
    That's when it pays to have long, gangly arms I guess.
  1. 2 unsused wires...what are they for...?
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-14-2008, 01:11 PM
