Thread: What should I change?
Results 1 to 11 of 11
  1. #1 What should I change?
    Punta Gorda, FL
    Ok so I bought a wreaked GTP for cheap a few months back and I finally got the money up to get this swap done. The motor has 78k miles on it and I was wanting to know what you guys would suggest I change on it. The car might have been at such a angle that oil was in the intake so with that in mind I already picked up the aluminum intake gaskets, and a supercharger gasket. Also have both belts for it because they where bad. Also got a new thermostat, always good to change out.
    Was just wanting to know what else I should change out before I swap motors in my GT. Thanks a bunch. Was thinking lower gasket set and valve cover gaskets.
    2000 Pontiac Grand Prix GT (98' L67 engine/trans swap)
  2. #2 Re: What should I change?
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    put the scer on the gt engine
  3. #3 Re: What should I change?
    Apr 2009
    stockton ca
    What he said i think Just top swap the supercharger on to your gt engine get a little bump in hp from higher compression of the n/a block in your gt
  4. #4 Re: What should I change?
    Wichita
    Aweful lot of work to top swap the S/C onto a GT. Not to mention the GT's tranny may not hold up against the S/C.
  5. #5 Re: What should I change?
    Barksdale AFB, LA
    It'll hold up just fine as long as you're not doing burnouts.
    2009 Subaru Impreza WRX STI
  6. #6 Re: What should I change?
    Jersey
    Quote Originally Posted by Sabrewings View Post
    and as long as you don't do wot runs going into 4th. But, that kinda goes with any 4t65e from 97-02.
    16' wrx sti- stock
  7. #7 Re: What should I change?
    Barksdale AFB, LA
    Quote Originally Posted by 99prixgt View Post
    True. Like you said that's both the HD and non-HD versions. I was referring to what made them different as far as what they can and can't take.
  8. #8 Re: What should I change?
    Apr 2009
    stockton ca
    it all depends how much your into working on cars
    if it were me I would pull both engines swap parts over and the swap trans over So in the end you have a trans that can hold up and a few more hp If you want it easy and clean just swap the gtp engine over change the basic items that wear out and call it a day
  9. #9 Re: What should I change?
    Wichita
    Yeah that would work. Good luck!
  10. #10 Re: What should I change?
    Punta Gorda, FL
    Well I forgot to mention that the reason I bought the GTP was due to the fact that my Trans is shot. 4th has been gone and I have a major 1-2 flare when its warming up. Going the root to spend the least amount of money I'm just swapping both engine and trans.
    Also I need to get both axles, the ones from the GTP seem alright but it was crashed so just going to go ahead a get some remained, who seems to have the best? Was going to get NAPA, but was thinking I might hit up Carquest.
  11. #11 Re: What should I change?
    Apr 2009
    stockton ca
    you can check out Morad aswell for halfshafts
  1. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  2. anyone ever change a gt to a gtp
    By e56505 in forum General Tech Discussion
    Last Post: 02-18-2009, 12:12 AM
  3. How soon do you change the oil after........
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2009, 03:56 PM
  4. pulley change
    By ROTTMAN in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2009, 09:13 PM
  5. s/c oil change
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2008, 05:44 PM
