Thread: ABS/TCS Lights
Results 1 to 6 of 6
  1. #1 ABS/TCS Lights
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    Yeah, so I was driving around today and I hit a bump in the road and instantly my ABS and TCS OFF lights came on. And pressing the TCS button itself did not affect this, my TCS is definately off and I can't figure out how to get these lights gone and function back to normal. Anyone else had this problem?
  2. #2 Re: ABS/TCS Lights
    SE Level Member Skeeve's Avatar
    carneyville FL
    It probably wasnt a bump in the road, that bump you felt was the crankshaft position sensor, seems to be a common problem with these cars, happens to me all the time, usually turning the car off and back on fixes it(temporarily)
    did your tachometer die also?
    99 Grand Prix GT
  3. #3 Re: ABS/TCS Lights
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    have had this problem, as long as your sure it was a bump check your connections, i have one that likes to try to pop out all the time
  4. #4 Re: ABS/TCS Lights
    Apr 2009
    Cresco, Iowa
    Quote Originally Posted by stlmo_gtp View Post
    Which connections and where? Thanks
  5. #5 Re: ABS/TCS Lights
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    a bad wheel bearing will cause the problem your having. or a bad connection between the abs sensor/wheel bearing and the computer. i would definitely check the wiring. that is what caused me to have your exact issue
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  6. #6 Re: ABS/TCS Lights
    St. Louis
    Quote Originally Posted by Jakegday View Post
    just like he said... if you jack up the car you can look behind the wheel and see where the wires plug into the hub, i usually unplug and then replug to make sure i get it to snap into place (do this for all 4 sensors) if it still isn't going off then you could have a short or a bad hub which then it is easier to go get it scanned to find out which one is bad. On a side note its a long shot but there is also an under the hood fuse you may want to check
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. HID and fog lights
    By Alpha388th in forum Visual/Body Modifications
    Last Post: 02-25-2009, 09:18 AM
  3. HID lights
    By mzendano in forum Visual/Body Modifications
    Last Post: 12-22-2008, 02:25 PM
  4. ABS and TCS Off lights are on
    By 03GTPFour in forum General Tech Discussion
    Last Post: 04-23-2008, 10:10 AM
