Thread: have some interesting questions
Results 1 to 9 of 9
  1. #1 have some interesting questions
    fall river mass
    Ok so after spending the last couple days reading alot of posts on this site I just have a few questions
    1. What exactly is knock retard ?
    2. Where can I get a scan tool and what ones the best ?
    3. Can u run a 3.5 pulley with little to no mods (I know for the 3.4 u need alot of mods and its unsafe but one of the performance sites said 3.5 pulley for stock gtp)
    4. Where should my knock be when I look for it ?
    5. I noticed everyone says colder plugs and i see autolite 104s alot but I look at autozone.com and advanced and they both say autolite 104s are not for the gtp and they dont list them under it ?
    sorry for so many I tried answering most of them by readin posts but these are the ones im still tryna figure out...
    thanks, Nick
  2. #2 Re: have some interesting questions
    Barksdale AFB, LA
    Quote Originally Posted by JunkboxGTP View Post
    Sticky in this section...
    http://www.grandprixforums.net/f18/w...here-1507.html
    Zero.
    That's because they don't come stock in it. The 104s are colder and Auto Zone are idiots.
    2009 Subaru Impreza WRX STI
  3. #3 Re: have some interesting questions
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    Read this.
    Read all of it, you will be quizzed.
    Im not kidding. :P
    2006 Grand Prix GXP
  4. #4 Re: have some interesting questions
    LOL^^
    Good deal, even after Sticky-ing it I still have to whore it out in every thread
    Read, read, read...and make the pulley drop your LAST in your first set of mods.
  5. #5 Re: have some interesting questions
    fall river mass
    thanks for the help but I have read the sticky and I know your supposed to do at least a downpipe, high flo cat, colder plugs, thermostat and ecu etc... but I noticed everyone says for 3.4 pulley. On a couple sites that sell the pulleys they say 3.5 is ok for stock and from what people say the 3.5 and 3.4 is night and day difference... thats why I was wondering thats all...
    Also where can I get a scanner and whats the best one ?
    Thanks again, Nick
  6. #6 Re: have some interesting questions
    SE Level Member FRESCOLIO's Avatar
    CHICAGO
    Informative......Thanks
  7. #7 Re: have some interesting questions
    CHICAGO
  8. #8 Re: have some interesting questions
    Jan 2009
    Michigan
    stock gtp's have kr so i wouldnt swap to ANY pulley without scanning first. you can either get tuning software (which is also going to scan) or you can get something like an aeroforce (cant do any tuning to the pcm). canned tunes (zzp 1.0, etc.) are kinda dumb to do now, imo, since you can get a used powrtuner for ~250.
    1. Knock Retard
    2. look for a used tuner or scan tool on the forums. you could use hptuners, but is too expensive for me. powrtuner is enough.
    3. i wouldnt touch the sc pulley
    4. nothing but zero. this becomes increasingly important the more power you make.
    5. thats because they want you to run platinum plugs. they also go by oe parts. copper plugs take heat out of the cylinders much better than platinum plugs do. another thing is that most platinum plugs have a sharp tip on the electrode, which can make for a "hot spot", not helping in the battle against kr at all. imo the reason platinum plugs were oem for these cars is because they last a while. most people dont want to have to change plugs every ~7k-10k miles.
  9. #9 Re: have some interesting questions
    Jan 2009
    Tallahassee, FL
    Read the stickies first, knock is what will destroy your motor, and it will get worse with a pulley drop so that's why you need other supporting mods first.
    For a scanner either go straight for HP tuners (to tune) or get an Aeroforce gauge that will read many of the parameters of the car.
    Something else, every car is different. Some people can run X setup for a 3.4 and others have to run Y setup for a 3.4, I might need rockers to run my 3.4 right now while other people don't need them at all. Don't read the ZZP guides for pulley drops, they're usually wrong.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  1. Interesting Intake option
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 05-28-2009, 08:23 AM
  2. Interesting article
    By Bogers99GTP in forum Off Topic Discussion
    Last Post: 01-21-2009, 08:06 PM
  3. Interesting battery
    Last Post: 07-07-2008, 10:07 AM
  4. Interesting Transmission
    Last Post: 06-25-2008, 11:23 AM
  5. Another interesting Engine
    Last Post: 02-03-2008, 07:55 PM
