Thread: Diff. in SE, GT, and GTP fuel pumps?
Results 1 to 5 of 5
  1. #1 Diff. in SE, GT, and GTP fuel pumps?
    Feb 2009
    NE
    My son called from college Saturday and GTP would not start. I went and looked at it and it had no fuel pressure and cycling key could not hear the high pitch whine of pump running. Long story short a friend had a GP SE parts car I got a fuel pump out of on Labor Day and put it in and now GTP is fine. Is there a diff. in the GTP fuel pump or is this one fine to leave in?
  2. #2 Re: Diff. in SE, GT, and GTP fuel pumps?
    GT Level Member BoostedComp's Avatar
    Youngstown
    dont quote me on it.. but if it was the 3800 motor in the se i would give a likely guess that they are the same
  3. #3 Re: Diff. in SE, GT, and GTP fuel pumps?
    all the same. anyone that tells you differently is weird. i used my GT fuel pump on my l67 swap and never ran out of fuel.
  4. #4 Re: Diff. in SE, GT, and GTP fuel pumps?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I guess I won't disagree that I'm weird, so here we go.
    From the parts list, the 3.1 and the 3.8 got the same pump from 1998-2000. The SC 3.8 had a different pump, I'm assuming it had something to do with those years having a high and low mode. For 2001-2002, the three engines each got a different pump. I couldn't tell you what the differences are, I have no idea.
    The biggest thing I would worry about is running low mode on a pump not designed for it. For the most part, these pumps don't like to be starved for power. What model years are involved?
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: Diff. in SE, GT, and GTP fuel pumps?
    Donating Users Liquifire's Avatar
    Wausau, WI
    Is it also the same for the 3.1 motor?
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  1. HD Diff???
    By 05grndprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-31-2008, 08:26 AM
  2. Diff between S/C L32 and an S/C L67
    By Keet04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2008, 06:50 PM
  3. Tranny whine after diff and diff case replace...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2008, 09:27 PM
  4. Gas Pumps
    By Abrasive in forum The Rant Forum
    Last Post: 02-03-2008, 10:25 AM
