Thread: HELP! Can't remove crank pulley bolt!!!
Results 1 to 20 of 30
  1. #1 HELP! Can't remove crank pulley bolt!!!
    Chi-boogie Ill-noise
    I need to remove the crank pulley/harmonic balancer on my '00 GTP and I can't get the F***er loose!!!! I haven't found a way to stop the pulley from rotating. Even used an impact wrench...to no avail!!! I need answers fast! This is my only mode of trans and this is about the only opertunity I will get to work on my car due to my schedule!!! (have to replace crank and cam sensors).
  2. #2 Re: HELP! Can't remove crank pulley bolt!!!
    is the motor out? If so stick a screwdriver through the flywheel and go to town with a breaker bar. Done it twice now.
  3. #3 Re: HELP! Can't remove crank pulley bolt!!!
    Nope! still in the car!
  4. #4 Re: HELP! Can't remove crank pulley bolt!!!
    Feb 2008
    Or, if the motor is still in the car, place a pair of locking pliers on the flexplate and rotate until they jam up against the bell housing.
  5. #5 Re: HELP! Can't remove crank pulley bolt!!!
    lift more weights. i wasnt moving mine too far either until i borrowed my brothers (mechanic) good impact. zipped it right off in about 10 seconds.
  6. #6 Re: HELP! Can't remove crank pulley bolt!!!
    May 2008
    McHenry IL
    true that ha
  7. #7 Re: HELP! Can't remove crank pulley bolt!!!
    Banned - Busted For Scamming
    Feb 2009
    Ive already mentioned the other way, but no one likes it.
  8. #8 Re: HELP! Can't remove crank pulley bolt!!!
    Is this thing reverse thread? No way in hell is this thing moving!!!
  9. #9 Re: HELP! Can't remove crank pulley bolt!!!
    This is un-fickin-believable!!!!!!
  10. #10 Re: HELP! Can't remove crank pulley bolt!!!
    Jersey
    I got fed up and did the starter trick, it worked well. If you do it make sure your coil pack is disconnected and all belts are off. Use at your own risk, i won't be responsible if you break something.
    http://www.youtube.com/watch?v=S_-FsVvNr40
    16' wrx sti- stock
  11. #11 Re: HELP! Can't remove crank pulley bolt!!!
    Feb 2008
    It's right-hand thread. I had to use a 24" breaker bar with a 3' pipe on the end to get mine to break loose.
  12. #12 Re: HELP! Can't remove crank pulley bolt!!!
    Apr 2009
    stockton ca
    hit it nice and hard on the head of the bolt with a ball peen to shock the bolt its not fail proof but works some of the time
  13. #13 Re: HELP! Can't remove crank pulley bolt!!!
    Jan 1970
    Maquoketa, Iowa
    Last week had one not budge at all, so i sprayed a little wd40(all we had) and then put the impact on it again for a few minutes and it came out very slowly.
  14. #14 Re: HELP! Can't remove crank pulley bolt!!!
    Starter trick...new to me. Suggesting that I secure the
    braker bar and then try and turn the motor over?
  15. #15 Re: HELP! Can't remove crank pulley bolt!!!
    Feb 2009
    Thats how ive always done it.
  16. #16 Re: HELP! Can't remove crank pulley bolt!!!
    Feb 2008
    It works. Just make sure the breaker bar is SECURE. otherwise you may have a 2' long piece of steel spinning around wildly in your engine bay!
  17. #17 Re: HELP! Can't remove crank pulley bolt!!!
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    i had to change mine last week... a little liquid wrench on the bolt, put a pair of vice grips on the fly wheel and then get yourself about a 3' breaker bar and you will be good to go
  18. #18 Re: HELP! Can't remove crank pulley bolt!!!
    Charles City, IA
    I know its more than most would like to spend but MG725, Impact Wrench, Air, Heavy Duty, Magnesium Housing, Standard Anvil, 1/2" drive . I love mine.
    SMGPFC Two Nipple General
  19. #19 Re: HELP! Can't remove crank pulley bolt!!!
    Feb 2009
    NE
    Take the access cover off the flywheel from below and clamp a vise grip on the flex plate. (not the ring gear though) That will hold the engine. I just did it 2 weeks ago with my GTP.
  20. #20 Re: HELP! Can't remove crank pulley bolt!!!
    Thanks gang! After five hours of fighting with the darned thing, I ended up trying the starter trick...and it worked! Thanks for all suggestions.
  1. Crank Pulley out of Position
    By marcheer in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-26-2011, 02:43 PM
  2. How do you get the crank pulley/harmonic balancer off???
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 11:08 PM
  3. How to hold Harmonic Balancer Still to Remove Crank Bolt?
    By pontiackid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 09:00 PM
  4. Crank Pulley/Balancer Opinions
    By BlackGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2009, 09:50 PM
