Thread: My S/C Port
Page 1 of 3 123 LastLast
Results 1 to 20 of 47
  1. #1 My S/C Port
    Wichita
    Okay so I got my S/C ported locally here in Kansas. I had to compare it with a stock S/C & other aftermarket jobs. Heres mine next to a stock S/C:
    And heres the wbodystore port:
    I've never seen an M90 ported the way mine is. Do I loose boost? If I can drop a pulley size with that insane port job I deffinatly will.
  2. #2 Re: My S/C Port
    Banned - Busted For Scamming
    Feb 2009
    I dont know, that looks way over ported to me, but without actual test results you never know. I dont know if the air has enough time to be ramped around with the way that was ported.
  3. #3 Re: My S/C Port
    Bastard Reptile's Avatar
    Kansas City, MO
    Wow.....that looks waaaaay over done.
  4. #4 Re: My S/C Port
    The rotors have nothing to push against...wtf
  5. #5 Re: My S/C Port
    Charles City, IA
    didn't you take that to mizley or what ever they are called?
    SMGPFC Two Nipple General
  6. #6 Re: My S/C Port
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    I would say put it on and try it out, who knows maybe it will surprise you with some crazy cool result probably not.
    The reason why i doubt the efficiency of the blower is because the overall design of most superchargers. They have an obvious triangle for an outlet, not what you have (square on a triangle). And the triangle is a certain size in comparison to the rest of the blower.
    Make sure the rotors aren't scraping against anything, put it on and try it out. Make sure you have a scan tool and or a boost meter.
    2006 Grand Prix GXP
  7. #7 Re: My S/C Port
    Jan 2009
    Tallahassee, FL
    That does look way overported. Let us know how it works for you.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  8. #8 Re: My S/C Port
    Wausau, WI
    I hope this goes well for you...........where did you have the work done? Have they ported these before for use on our cars?
  9. #9 Re: My S/C Port
    youre not supposed to make the outlet bigger...where did you get the idea for that?
  10. #10 Re: My S/C Port
    He didn't. A place in Wichita called FTW Motorsports did it.
  11. #11 Re: My S/C Port
    Wichita
    Yeah it deffinatly wasnt what I was expecting. If it turns out alright after I get the car scanned then I'll keep it on. Might hafta' drop a pulley size or two to make up for lost boost pressure? Lucky me I have a spare M90 to fall back on
  12. #12 Re: My S/C Port
    Feb 2009
    Have they done others like that before?
  13. #13 Re: My S/C Port
    I bet that blower whines like no ones business though.
  14. #14 Re: My S/C Port
    whine comes from the compression. if the blower doesnt compress the air, then no whine happens. with how wide open that is, i dont think it will whine.
  15. #15 Re: My S/C Port
    Meh, it goes both ways...when mine was hogged to **** like in my XP start up vid on youtube...it was just ported like crazy and it whistled at idle AND whine pretty damned loud.
  16. #16 Re: My S/C Port
    Wichita
    Yours was over ported like that? Darn. How well did it work for you?
  17. #17 Re: My S/C Port
    Wichita, KS
    Well it looks nice, not how I do them, but for sure better than some of the hack jobs I have seen.
    If it works well, then
    If it does not...then
    ~F~
  18. #18 Re: My S/C Port
    No...mine was still in the basic "V" pattern, just ported more than normal...not taken out like yours is.
  19. #19 Re: My S/C Port
    Wichita
    Let's hope it does
  20. #20 Re: My S/C Port
    Wichita
    My Car Lives!!! I hasn't got power steering though. I cracked that line. Gonna be another day or so before I can really see how that port works for my car.
  1. Port on top of trans...
    By GTPrix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-24-2013, 11:07 PM
  2. How to port your m90.
    By minichopper6hp in forum How To Write-Ups/Tech Tips
    Last Post: 09-03-2009, 04:32 PM
  3. low presure ac port
    By samborski06 in forum General Tech Discussion
    Last Post: 06-17-2009, 03:09 PM
  4. Best way to do a home port job on a s/c and LIM
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2009, 12:28 AM
  5. Port my LIM???
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2008, 09:50 PM
