Thread: problem after intercooler install
Results 1 to 6 of 6
  1. #1 problem after intercooler install
    Not on here anymore
    just installed a st2 IC from zzp with functional PCV.. The 2 yellow orings i was told do NOT need to be installed since the holes were filled in (Could this be a issue? do i still need to put those in)?
    at first start up no vac leaks appeared but idle strange
    then we took it for a test drive and got into it and slowed down to where the car died on us.
    started it back up and it didnt want to run and sounded like a vac leak so we sprayed everything down with carb and choke cleaner to find a leak and there is NOTHING..
    the loud grinding is from a bolt we need to cut down that is hitting the idler pulley..
    any and all help asap would be awesome! anyone have any idea?
    http://www.youtube.com/watch?v=IFsvVL_YWMY VIDEO
    heres a new video with the bolt cut off no grinding noise
    http://www.youtube.com/watch?v=98bODy8U7yY
  2. #2 Re: problem after intercooler install
    in a house
    If the coolant holes were plugged then you wouldnt have to install the orings and this isn't the problem. Sounds like a vacuum leak. Do you have something to scan with?
  3. #3 Re: problem after intercooler install
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    Quote Originally Posted by qball98 View Post
    What exactly did you spray down?
    Did you check all of your electrical connections? Sometimes things pop off accidentally that may have not necessarily been in the area you were working in.
    2006 Grand Prix GXP
  4. #4 Re: problem after intercooler install
    in a house
    Actually after seeing your vac/boost guage almost at zero I would say you have a large vacuum leak.
  5. #5 Re: problem after intercooler install
    Donating Users gtpsleeper's Avatar
    Lawrence, Kansas, United States
    Quote Originally Posted by silverstreak View Post
    check the gauge line
    "My car is a racecar like Planet Fitness is a gym...."
    proud mark VIII victim!!! suck it...
  6. #6 Re: problem after intercooler install
    Not on here anymore
    cant find a vac leak and i did recheck the line for gauge
  1. Intercooler install pics & help?
    By qball98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 01:06 AM
  2. Full Size Intercooler Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2009, 12:38 AM
  3. How to install stage three intercooler?????
    By GINOSGTP in forum General Tech Discussion
    Last Post: 02-25-2009, 07:52 PM
  4. how do you install an intercooler??
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 05-25-2008, 12:15 AM
  5. Handful of Questions for an Intercooler Install
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2008, 07:27 AM
