Thread: injector swap question
Results 1 to 12 of 12
  1. #1 injector swap question
    GT Level Member riceburner's Avatar
    Aug 2008
    denver, co
    so i was just curious if the stock injectors off an LS1 would work if swapped onto the L67 platform?...
    '01 GTP mods: K&N intake, autolite 104's, drilled 180*, !u-bend, !EGR, ported s/c, polished heads and TB and a LOT more whine
    '99 firebird mods (1 of 6): LS1 swap, custom exhaust, LS6 IM, RA intake, and a few suspension parts
  2. #2 Re: injector swap question
    Moore, Oklahoma
    IIRC, I think they flow less so it would be a downgrade.
    If your going to swap in anything, at least get 42.5#. Whatever you do though, the PCM will need to be tuned for the different injectors. Otherwise your car will either run pig rich or won't run at all because of being too rich.
    Looking at your mod list you DON'T need injectors right now, it won't do anything for you...
    Shawn W. Larsen
  3. #3 Re: injector swap question
    LS1= #28lb
    LT1= #24lb
    GTP = boosted so #33lb stock...
    Get Ford Lightning or '03/'04 Cobra injectors...but FYI, your no where near needing them for your GTP.
  4. #4 Re: injector swap question
    Aug 2008
    denver, co
    i am in need cause one of mine is shot...and i was just trying to figure out a cheap way to remedy it...since im hella broke at this time...
  5. #5 Re: injector swap question
    Wausau, WI
    you have to swap them out as a set if you are going to do so. If you need one, just find one from a junkyard, ed morad, etc.... or just buy one new if you can afford it.
  6. #6 Re: injector swap question
    Quote Originally Posted by Liquifire View Post
    What? Where'd you get this? If one injector is bad and you know which one it is then you trash the crap one and put in a different one. Riceburner...I am upgrading to #42.5lb. injectors here soon and you can buy my whole injector set from me and I'll throw in new O-Rings for $50 + shipping if you want to do that...shoot me a PM if you want.
  7. #7 Re: injector swap question
    Wausau, WI
    how can you just put in one 42# injector and run the rest stock injector size? Dont you have to tune for one specific injector size? I meant when upgrading you must have one specific set size that you are upgrading to, you can't mix and match....
  8. #8 Re: injector swap question
    I was going towards the fact you said he had to re-tune it for swapping one bad stocker for one good stocker.
  9. #9 Re: injector swap question
    Aug 2008
    denver, co
    so one more ?...would any 3800 coil pack work for the gtp?
  10. #10 Re: injector swap question
    Wausau, WI
    they are different part numbers, so they should be different....from the NA to the GTP that is. Atleast, that is what I have read. I never actually have swapped them out to see.
  11. #11 Re: injector swap question
    Aug 2008
    denver, co
    hum cause i have a misfire on #4 and swapped the "problem" injector but code did not follow....leading me to think its the coil...
  12. #12 Re: injector swap question
    Wausau, WI
    can you get a coil pack from a junkyard to swap out?
  1. Top Swap Question
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-08-2009, 06:34 PM
  2. pulley swap question
    By jersey jok3r in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2009, 12:04 PM
  3. Pulley swap question ------>>> NEW GUY
    By mjm06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 01:00 AM
  4. another top swap question
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-20-2009, 12:59 PM
  5. LOL another top swap question
    Last Post: 01-21-2009, 05:40 PM
