Thread: 06 GT SC starting problem
Results 1 to 6 of 6
  1. #1 06 GT SC starting problem
    Aug 2008
    Birmingham, AL
    I'm not sure if I'm posting this in the right place, so please let me know if there's a better part of the forum to ask... Have an '06 Grand Prix GT (Super Charged) that just started having an intermittent starting problem. Turn the key and it clicks for about 20 seconds after I let the key go; then briefly turns over one time after the clicking stops. Turn the key again and the car starts. If this was a car I was familiar with, I'd say it's a bad starter. Battery and alternator both check out, so it doesn't appear to be a charging system problem.
    I haven't looked underneath the car yet to see where the starter is, but I can't seem to find a starter for this engine at the usual Auto Zone, Advance, NAPA. I assume it has a starter... Anyone else ever had this problem and can offer some advice? Thanks in advance for your help!
    John
    Birmingham, AL
  2. #2 Re: 06 GT SC starting problem
    Charles City, IA
    Could be a bad starter or a bad connection between the battery and the starter.
    SMGPFC Two Nipple General
  3. #3 Re: 06 GT SC starting problem
    Apr 2009
    stockton ca
    Yea I would check all your basic connections also if your headlights dim severly id say its a battery alt issue id also have autozone test the charging system on the car as they do it free
  4. #4 Re: 06 GT SC starting problem
    SE Level Member GeeBee's Avatar
    Iowa
    Is it a solenoid click or a grinding click like the gear for the starter isnt connecting proper?
    2006 Grand Prix Gt - Wizair, Solid Poly Mounts
    1996 Olds 98 Regency Elite - Dieing of Car Cancer and old age.
  5. #5 Re: 06 GT SC starting problem
    Donating Users Liquifire's Avatar
    Wausau, WI
    my guess is starter, and yes you do have one........
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  6. #6 Re: 06 GT SC starting problem
    SE Level Member busagtp's Avatar
    chicago
    I'm having the same problem on my 04 gtp, but mine started one time, now it won't start. I had just finished a tune up but now i'm just getting the clicking sound, i was thinking the starter also but i can't see it from underneath because of the dust cover if i figure it out i'll let u know
  1. Starting Issues
    By BigBird in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-20-2009, 12:22 PM
  2. Work is starting soon on the new GTP
    By 2000GTP in forum Off Topic Discussion
    Last Post: 01-19-2009, 09:41 PM
  3. 04 gt starting problems
    By borst24 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2008, 10:10 PM
  4. starting problems
    By redgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2008, 12:24 AM
