Thread: Slow labored cranking
Results 1 to 5 of 5
  1. #1 Slow labored cranking
    Philadelphia
    Today when I tried to turn my car on after fueling up, it would not start. I only got 1 click so I tapped on the starter with a hammer. I got the car to eventually start after a slow crank. The car has started probably 5 times since the first non-start, but every start has been a very slow crank taking about 2-4 seconds until the engine fires up. Also, I noticed after the car starts up the radio clock resets to 1:00. Also, with the key in the ON position but not all the way cranked, the car has full power with the dash lights and radio powering on. I check the battery terminals and everything seems to be clean and snug. Can anyone please provide any help with this issue? Is it the starter itself or battery? Any suggestions?
  2. #2 Re: Slow labored cranking
    slow crank = bad battery.
    no crank = bad starter.
    loss of voltage and dying when running = alternator.
  3. #3 Re: Slow labored cranking
    Wausau, WI
    either your alternator is not charging the battery correctly.....or your battery is shot. Most likely it is the battery as the car runs fine once the alternator(and motor) is running. Get a new battery........you could go to an autozone or some other parts store and have them test your alternator for you..........then you would no for sure........I would bet it is the battery though........
  4. #4 Re: Slow labored cranking
    Philadelphia
    Yeah it's strange. The car has been slow cranking for about 2 weeks now, but it starts eventually. I would bet it is the battery also as I noticed the horn is a bit dimmer when I set the alarm. Thanks fellas. I appreciate it.
  5. #5 Re: Slow labored cranking
    Wausau, WI
    the horn is dimmer?
  1. '98 SE L36, no fuel pressure while cranking
    By 98SEGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2009, 01:56 AM
  2. why does my car die when i slow down? I need help!
    By joeyG97 in forum General Tech Discussion
    Last Post: 05-20-2009, 01:22 PM
  3. Does my car seem slow?
    By Toofastgs in forum Off Topic Discussion
    Last Post: 04-18-2009, 07:28 PM
  4. slow
    By Toasty in forum Off Topic Discussion
    Last Post: 02-12-2008, 07:03 PM
  5. You Guys are all slow !
    By Meemperor in forum Canada
    Last Post: 01-08-2008, 09:33 PM
