Google Image Result for http://i4.ytimg.com/vi/SC_Eh9LFIuY/default.jpg
haha wow cool idea and it worked![]()
joe........is your motor gonna be on a stand or in a car? LOL.......maybe you can get that motor from him and put it in your car.........it sounded good atleast.
cant run a motor without backpressure for long without burning the valves. you need SOME backpressure. i do it to my bike just about every year because i like to run it with no mufflers.
great. had a fresh rebuild on it last winter for the motor and transmission. the only problems with it that ive had this year is that a bolt fell out in the ignition and sheared off all of the contacts. scared the crap out of me and i thought it was the bottom end finally letting loose. replaced the destroyed parts and it runs like a champ.
its old, but i bet with a good launch itd run consitant 11s.
can someone explain why it will burn the valves?
Anyone concerned that there's no acc belt? Means no water pump, which means for that matter I don't see any cooling of any kind.
We have a series one n/a rigged up on a stand at school that runs. It even uses the factory pcm. We have about 2' of pipe on it with a muffler sitting on it that says hemi.
