Thread: Narrowband or wideband o2?
Results 1 to 10 of 10
  1. #1 Narrowband or wideband o2?
    SE Level Member SilverGT's Avatar
    Feb 2009
    Saskatchewan Canada
    Okay so I am lightly modding my GTP. Not going to do anything crazy with it. I know that most narrowband gauges have a tendency to jump back and forth and are next to useless. I have heard good things about the summit racing a/f gauge. I just want something to monitor my AF ratio so I know that I am not running lean and something easy to install. I wont be tuning it any time soon since money will be tight when Im going to school so I will be buying a tuned PCM.
    So I am asking, Is a narrowband AF gauge going to be sufficient to monitor my AF ratio? Or should I just go with a wideband?
    I will also be running an Aeroforce gauge to monitor KR.
    Mods:
    TDC FWI
    MSD Wires
    TR55 Copper plugs
    ZZP 2.5" bolt in offroad downpipe
    Plog, cross over pipe and tuned PCM (Coming soon)
    Maybe a 3.4 pulley (next year)
  2. #2 Re: Narrowband or wideband o2?
    Wausau, WI
    I would go with the wideband....especially if you are going to the 3.4 setup you will need a tune.
  3. #3 Re: Narrowband or wideband o2?
    Donating Users chrisb's Avatar
    Bucyrus, OH
    narrowband sensors are only accurate when close to stoichiometric, they can only tell you when you passed the target afr not where you are at the present time. Once you go wot you will be out of the narrowbands range making it pointless to monitor afr unless you are close to stoichiometric (14.7 afr). Now a wideband can monitor anything from 8:1 to 20:1 afr and will tell you where you are at the present time.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  4. #4 Re: Narrowband or wideband o2?
    Charles City, IA
    Get a wideband. I have a ngk afx.
    SMGPFC Two Nipple General
  5. #5 Re: Narrowband or wideband o2?
    May 2008
    staten island,NY
    wideband
  6. #6 Re: Narrowband or wideband o2?
    Feb 2009
    Saskatchewan Canada
    Alright wideband it is! Ill be grabbing an AEM Wideband.
  7. #7 Re: Narrowband or wideband o2?
    Jan 2009
    Tallahassee, FL
    And get a 3" dp, especially if you are going to run a 3.4.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  8. #8 Re: Narrowband or wideband o2?
    narrowbands dont tell you anything at all. get a wideband.
  9. #9 Re: Narrowband or wideband o2?
    Charles City, IA
    they can tell you if you are epileptic lots of flashy lights
  10. #10 Re: Narrowband or wideband o2?
    Bucyrus, OH
    haha yeah thats true.
  1. wideband o2 kit
    By popeyenate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2009, 12:44 PM
  2. Wideband AFR where should....?
    By GTP4 in forum PCM Tuning
    Last Post: 04-21-2009, 11:57 AM
  3. Anyone run an LC1 Wideband...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 03-24-2008, 09:41 PM
