I was finally able to put a tech2 on my car to scan it today Due to a trans problem dtc and it said the car has 0 kr and i left it hooked up for test drive.
Just curious if 0 kr is normal I know its optimal but i was just curious
i figured as much just checking
mine says absolutely no knock on my setup according to my aeroforce guauges...fwiw....I have never seen anything on it other than 0.0
yep, seriously........but you had a higher comp stock though too even with the stock pulley. I also have seen as much as 9 psi boost stock(need exhaust mods now.......LOL) which seems higher than most
maybe it was a rod knockin........seriously, I had no idea a stock GT would knock...wow.......did you have two cylinders blocked off in the manifold or what? did you just have a little KR or how much?
I think I can just slap a 3.4 on it right now and have 16 psi of boost and no knock....sounds good, right? LOL
o is good.......
Well a stock pulley and no U-Bend...its postible![]()
