Thread: High Oil Pressure
Results 1 to 6 of 6
  1. #1 High Oil Pressure
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    97gtp with 82k miles on it. Just did an oil change last week and put maybe 400 miles on it.
    I accelerated quickly to cross an intersection and got on the highway. Once on the highway I was cruising for about 5 mins when I realized my Oil pressure is 138 psi. I end up dropping my sister off at the airport and headed back to my place. Upon shutting it off I could see the oil pressure drop on the gauge. I restarted it again and the pressure varies between 129-140 psi. Normally I sit around 45-70 psi while driving.
    Oil Pressure is monitored with corvette sensor and is hooked up to my aeroforce gauge. I just changed the oil last week which has at most 400 miles on it and used Mobil Extended Performance Full synthetic with a Mobil oil filter. Hopefully I didn't spin a bearing, but the engine is smooth and still accelerated fine so I'm thinking maybe oil relief is stuck
    Any ideas, maybe I'll use my manual oil pressure gauge tomorrow and hook it up.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  2. #2 Re: High Oil Pressure
    Wausau, WI
    I would double check the gauge first.........if it is accurate, you definately have an obstruction I would think..........I hope it is the gauge. check the oil filter if that is not it and cut it open and see if anything abnormal is in there...........
  3. #3 Re: High Oil Pressure
    Banned - Busted For Scamming
    Feb 2009
    I hate electric gauges, never know if they are working right.
  4. #4 Re: High Oil Pressure
    wow, thats high. sounds like somethings in the oil filter or clogging the pickup in the pan.
  5. #5 Re: High Oil Pressure
    SE Level Member BlackGS's Avatar
    Central Jersey
    Definitely take a couple minutes and spin on a new filter to see if that is the obstruction. Since you just changed the oil, it seems highly likely that filter is blocked somehow.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  6. #6 Re: High Oil Pressure
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    when the sensors go bad they show a high pressure reading. oil pressure sensor is probebly bad if the new filter doesnt take care of it.
  1. Replies: 0
    Last Post: 08-09-2009, 07:01 PM
  2. How High Is To High?
    By samsquanch in forum General Tech Discussion
    Last Post: 06-17-2009, 12:29 AM
  3. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  4. High Flo Cat
    By 04gpking85 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:24 AM
