Thread: New exhaust work: now my performance SUCKS!!!!
Results 1 to 20 of 31
  1. #1 New exhaust work: now my performance SUCKS!!!!
    Chi-boogie Ill-noise
    As you may see I am new to the forum. Wednesday night I puchased a 2000 GTP with 16300 mi. I couldn't resist the price! There really wasn't a ton wrong with it, but I began having it worked on IMMEDIATELY!!!. I had to replace the intake and supercharger gasket, belts, fluids, plugs, and thermostat. RAN LIKE GREASED LIGHTING!!! I knew that it had an exhaust leak, but it was a bad donut at the flange where the converter and the resonator meet. I took the car to the guy that normally does all of my exhaust and suspension work (needed new front struts and springs) and I let him talk me into replacing the exhaust from the downpipe back.
    Every thing is replaced w/what I believe is 2.5 inch exhaust ( I didn't measure it), but now my car runs like crap!!!! It sputters, hesitates, fuel mileage sucks and it has cut out on me! The problems showed up IMMEDIATELY. There is no guessing that the change in exhaust caused the issue.
    NOW:
    There is no bend coming out of the convertor into the resonator as before, so there is less back pressure, could that be an issue,
    OR:
    Is it possible that something needs to be recalibrated to make up for the change in exhaust,
    OR:
    Is it it possible that I have been dupped and have cheap or undersized components (Convertor) on my car, (my vote)
    OR:
    Possible O2 sensor problem when the convertor was installed?
  2. #2 Re: New exhaust work: now my performance SUCKS!!!!
    SE Level Member GeeBee's Avatar
    Iowa
    Er you mean 163,000?
    New plugs - is it re-wired in proper firing order, are the plug wires good, no cracking and routed proper.
    I had a plug wire routed wrong burn itself on the manifold just enough to short out, made it run like complete anus(i think it took out both cylinders on that coil) until i pulled over at a truck stop routed it proper and taped over the crack with electrical tape.
    Other than that - Make sure your crank sensor is good, my old 91 olds crank sensor started going bad and threw the timing to hell.
    Exhaust
    Almost sounds like the cat is clogged....did they mess with EGR on the exhaust work?
    PCM / 02....
    If the rear 02 is dicked its possible its gone into the catalytic converter diagnostic mode which would make it run rich and suck fuel but i dont think it would cause it to behave poorly....dunno tho only read about it.
    Is it stock from the previous owner or was it modded / demodded.
    2006 Grand Prix Gt - Wizair, Solid Poly Mounts
    1996 Olds 98 Regency Elite - Dieing of Car Cancer and old age.
  3. #3 Re: New exhaust work: now my performance SUCKS!!!!
    changes in the exhaust short of a big header/manifold leak will not affect performance. its something else.
  4. #4 Re: New exhaust work: now my performance SUCKS!!!!
    Quote Originally Posted by GeeBee View Post
    Exhaust
    PCM / 02....
    Everything was stock. Performance was okay when I purchased it Wednesday. Worked on it Thursday and Friday morn. Thats when the new plugs etc. went on. Performed like a champ!! Ran it Friday night no sweat. Saturday morn, no problem. Changed exhaust Saturday afternoon...turdjuice.
    Don't know about the EGR though...but you are correct, it is behaving as if it has a plugged/clogged convertor. Someone else suggested to check the fuel pressure regulator, but that just seems to iffy!
  5. #5 Re: New exhaust work: now my performance SUCKS!!!!
    Thanks, I originally thought the same but it was too drastic and immediate of a difference in performance to not say it had to be something there. Of course I was the LAST customer and I pull off as they are shutting down for the evening!!!!
    I shall return tommorow and see what they say.
  6. #6 Re: New exhaust work: now my performance SUCKS!!!!
    Wausau, WI
    do you have a vacuum leak? I am with bio......short of a major leak or a big time obstruction........the exhaust is not your culprit.......start searching......does it have trouble idling? any other info that we should be aware of?
  7. #7 Re: New exhaust work: now my performance SUCKS!!!!
    Nah, no trouble w/idling. Only under throttle. Headed to the shop in about 15 minutes. I will get to the bottom of this today hopefully.
  8. #8 Re: New exhaust work: now my performance SUCKS!!!!
    Wausau, WI
    good luck....
  9. #9 Re: New exhaust work: now my performance SUCKS!!!!
    Diags show that it's the EGR and Crank Sensor. Dude asked to repair it for me for the low price of $620....
    Unbelievable.
  10. #10 Re: New exhaust work: now my performance SUCKS!!!!
    Iowa
    #!@# him on the crank sensor, he prolly broke it in the first place ($15 part btw) I know it was possible to move the crank sensor on my series 1 which would throw it off timing - dunno about series 2/3 tho. Either way i'd tell that guy to !@#@ off on it and tell him he broke the EGR on the exhaust install and to fix it.
  11. #11 Re: New exhaust work: now my performance SUCKS!!!!
  12. #12 Re: New exhaust work: now my performance SUCKS!!!!
    Wausau, WI
    Quote Originally Posted by Billy Low View Post
    Unbelievable.
    did you have the same place that did your exhaust do the diagnostic analysis? If so, they should fix it as they broke it........if not then contact the people who did do your exhaust and see what they have to say....
  13. #13 Re: New exhaust work: now my performance SUCKS!!!!
    so your EGR is leaking?
    Didn't say. Just quoted a price.
  14. #14 Re: New exhaust work: now my performance SUCKS!!!!
    Quote Originally Posted by Liquifire View Post
    The guys who did the exhaust is who did the diags. They wanted to say that I needed a major tune up done. I told them I just installed new plugs, he said I must've installed crappy ones, so he pulled one and saw Delco. He claimed I needed a new air filter, I said nothing, he saw the new filter. He said, I needed a new fuel filter, wrong again. Strange thing is, I was watching the tech as he was running the diags, and I am almost 110% sure I saw EGR tests pass!!! ALL EIGHT OF THEM!!!
    I don't doubt the assumption that they broke somthing as you say. Like I said, the car ran fine before I went in for a simple leak!
    My regular mechanic will be back in town Wednesday. I just hope I can hold out.
  15. #15 Re: New exhaust work: now my performance SUCKS!!!!
    Wausau, WI
    yes.........wait for your regular mechanic and make sure it is someone you trust.......I hate dishonest shops........my worst pet peeve in the world......?
  16. #16 Re: New exhaust work: now my performance SUCKS!!!!
    Wausau, WI
    what type of plugs did you put in?( which model) not platinum I hope.........
  17. #17 Re: New exhaust work: now my performance SUCKS!!!!
    Iowa
    ummm the crank sensor isn't too bad if i remember right...
    get it jacked up and you should be able to reach it from below...i think you can re-align it without having to take anything apart.
    Think you undo the set screw and push it towards the harmonic balancer and use a feeler gauge to set the gap.
    If you actually have to replace the crank sensor its a good idea to do the harmonic balancer at the same time since its a PITA to pull and the rubber can go rot / tear and break free causing the inside to turn independantly from the outside making funny noises when you turn the wheel / run the ac....
  18. #18 Re: New exhaust work: now my performance SUCKS!!!!
    Yeah, I was thinking that the harmonic balancer may be an issue regarding the crank sensor. As for the EGR valve, where is it located on the GPs, (this is my first and I have yet to buy a manual but shall do so soon)?
  19. #19 Re: New exhaust work: now my performance SUCKS!!!!
    Nah, not platinum.
  20. #20 Re: New exhaust work: now my performance SUCKS!!!!
    Iowa
    i'm not sure but i think the EGR valve is the butterfly just behind your throttle body, but thats a guess..
    If your harmonic balancer is bad it wont throw off your timing since that is run off a magnet mounted to the center not the outside, but your accessories and supercharger wont turn proper.
    Changing the crank sensor req's pulling the harmonic balancer off so...If it looks like its dry rotted or can see stress marks in the rubber its $100ish part to replace which is less than the labor will prolly be if you have a shop do it.
  1. My intake sucks, my exhaust blows, and my car whines!
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2009, 09:13 AM
  2. ZZP (sucks)
    By 98GTPCALGARY in forum The Rant Forum
    Last Post: 04-08-2009, 07:24 AM
  3. Quiet Performance exhaust?
    By FuglyGTP in forum General Tech Discussion
    Last Post: 03-04-2009, 09:51 PM
  4. Having the flu sucks!!!
    Last Post: 12-18-2008, 04:34 PM
  5. exhaust work
    By mrbiggun1994 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-11-2008, 01:18 AM
