Liquifire
so you want lower vac at idle or what? I know max boost is not a good thing to go by because that only tells you how much resistance that you have getting the air out of your pump(motor/exhaust) so 8 pounds just means you are getting it out well. You may have a vacuum leak and if so check as stated above. Has it been this way for a long time? do you have a way to scan for it at all times? have you changed any parts recently or done any work which may have effected this? Checked brake booster?
