Thread: Puzzled and dont know where to start
Results 1 to 13 of 13
  1. #1 Puzzled and dont know where to start
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    Well i went out and had a little fun with some buddies tonight and everything was going great and then i reved up my car a bit and then this ticking started happening... at first i thought it was the S/C coupler so i took the belt off and spun the pulley and no noise and then just to verify i started the car with out the S/C belt on and the noise was still there... but here is where i get confused it only does it at an idle, and when you give it gas it slowly starts to go away?? an ideas on what it could be?at first i thought it was the valve train but wouldn't it continue to tick as the rpms go up? but now i am thinking bottom end... any help on where to start checking first would really help
  2. #2 Re: Puzzled and dont know where to start
    Jersey
    Its most likely lifter tick.
    A video would help. Does it tick on a cold start then fade away once warmed up?
    16' wrx sti- stock
  3. #3 Re: Puzzled and dont know where to start
    SE Level Member vsl67's Avatar
    Australia
    Does the US L67 Have two belts ,one for the motor and one for the supercharger like here in Australia ? If it does remove the engine belt and the sc belt and start it ,if the noise goes away it might be a noisey Idler bearing or if its still there take a piece of long rubber hose or a long screw driver put on the motor very carefuly while its running and hold it to your to try to isolate sound
    Also since the noise goes away when you rev it up, it could simply be a noisey lifter or rocker and its going quiet when the oil pressure increases and finaly injectors can make a ticking sound at times
  4. #4 Re: Puzzled and dont know where to start
    St. Louis
    Quote Originally Posted by 99prixgt View Post
    no doesn't matter warm or cold it ticks, i will try to post a vid once i get home from work
    Quote Originally Posted by vsl67 View Post
    took the S/C belt off and the noise was still there i am going to try to isolate it after i get back home... but from what it sounds like i think it may be over on the pulley side of the engine so i was thinking a bearing... idk yet and don't have the time to check it right now
  5. #5 Re: Puzzled and dont know where to start
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    ahhhhhhh. i think he stated that he did that already
  6. #6 Re: Puzzled and dont know where to start
    St. Louis
    alright guys here are a few vids... sorry about the quality all i had was my cell phone, i am lead to believe it has something to do with the crank pull as you will see in the second video... i don't think that it is suppose to move like it is.
    Car Running :
    By Hand:
  7. #7 Re: Puzzled and dont know where to start
    Apr 2009
    ERIE
    dude..if thats the harmonic balancer in the second vid then replace its bad. if you remove the balancer and the entire shaft still moves like that then you need to buy a motor instead
  8. #8 Re: Puzzled and dont know where to start
    Apr 2009
    ERIE
    just listened to first video...its the balancer
  9. #9 Re: Puzzled and dont know where to start
    Wausau, WI
    yeah.........replace that damn thing that is god awful sounding.
  10. #10 Re: Puzzled and dont know where to start
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by DOUGLASMELTER View Post
    He suggested to run it with both belts off, which is a good suggestion. Don't **** with the Aussies when it comes to these engines, they know their **** and this platform, it just goes by different names over there...
  11. #11 Re: Puzzled and dont know where to start
    Apr 2009
    ERIE
    Quote Originally Posted by FoSHO99 View Post
    sweet he can come work on mine anytime then
  12. #12 Re: Puzzled and dont know where to start
    Jersey
    that definitely sounds like a bad harmonic balancer.
    so...cheer up
    16' wrx sti- stock
  13. #13 Re: Puzzled and dont know where to start
    St. Louis
    yea i am a little happier now that i know what the problem is and lucky i have a buddy that works at the auto part store and can save me $20 bucks on it so that made me even a little happier
  1. If if dont make money it dont make cents
    By CrAnK_DaT_SoUjA_BoI in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 01:00 AM
  2. dont know where this should go
    By gtpinsc in forum Off Topic Discussion
    Last Post: 09-17-2008, 08:11 PM
  3. for those of you that dont look in regonals
    By Curtis in forum Off Topic Discussion
    Last Post: 05-06-2008, 09:16 PM
