Thread: What should my next mod be?
Results 1 to 20 of 27
  1. #1 What should my next mod be?
    Tofu Delivery Boy Lsick7's Avatar
    MO
    I need some help deciding my next mod. I should have close to $400 to blow in a few days or so, and it will definitely burn a hole in my pocket. Currently i have a 1998 GTP with 3.4 mps, dp, slp cat-back, tb spacer, JMB FWI, plugs, t-stat, and unfortunately a zzp pcm.
    So, with that said, i have 3 options in mind....
    1.) Green Bastard (Reptile) Supercharger/TB Port and Polish and GBP Tune
    or
    2.) SSAC Headers
    or
    3.) ZZP rockers and ls6 valve springs
    I'm leanin toward 1 or 2, but i can't make up my mind!!!!
    Gold Digger - still broke, lawn ornament
    05 M6 PBM GTO - Corsa exhaust, aem intake, bmr drag bags. More whenever I haz monies
  2. #2 Re: What should my next mod be?
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    If you have any desire/time to learn how to tune, i would buy a tuner. A good tune can drop close to a second off of your 1\4 mile. If i remember correctly someone claimed to have run a 99 stock GTP in to the high 13's with a really good tune.
    Your decision should be based on your mechanical expertise and goals.
    If you have a good deal of knowledge/skills i would go for the headers. Not too hard to install but problems with sealing could call for substantial welding. (I'm not sure about the track record of SSAC headers). Breaking a bolt in your engine block = no bueno, would you know what to do? You allready have a dp which would become useless if you get headers (some types anyway).
    Personally i would go with choice FOUR. You get the tuned PCM which you defiantly need (ZZP is garbage). You get the P&P, better S/C and TB efficiency, less KR and more whine! And you buy a Plog, the rear manifold isn't too restrictive however the front is, the plog will help allot. You don't need to lift your car to do this work and if you exchange your cores the price is amazing. All work is done on top and any problems you encounter would be easier to fix.
    Choice four would run you ~ $540 and ~$440 after you return the blower and tb cores. If you get the plog used you can knock another $40 off of that price at least, bringing you down to $400. You can probably even get something for the front exhaust manifold if you decide to sell it.
    2006 Grand Prix GXP
  3. #3 Re: What should my next mod be?
    Charles City, IA
    Get headers. I have ss autochromes just have to buy some nice band clamps and tighten them up real good.
    SMGPFC Two Nipple General
  4. #4 Re: What should my next mod be?
    none of those will give you a big kick in the pants. the ported blower/tb will be the most useless to you at this point in your modding. you will literally get like 5 hp from it at most. the headers will give you a little top end, but youre not to a point that you NEED headers yet. for rockers you need exhaust work for them to help out a bunch.
    i suggest you just wait and save up for an intercooler setup OR a cam setup. either of those should run around $1000, but your car will be a whole new beast with either one.
  5. #5 Re: What should my next mod be?
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    really? bio you dont think that a really good tune over the zzp pcm would benefit him at all? thats my next move is to get a good tune on my car. it would be the cheapest and easiest way to gain hp i think
    2003 GTP- 180 tstat,tb spacer,flipped dogbones,dhp pcm,3"catless dp,plog,thrasher fwi,3.4 pulley,msd 8.5mm wires,autolite 104s----------best run so far:14.1 @97mph
  6. #6 Re: What should my next mod be?
    That DHP in your car is the best PCM ever Don't bother messing with it until you get rockers/cam/IC. Damn near 13's with your mods in the midwest is quick.
    I say number one...that's only because I know how much I loved mine
  7. #7 Re: What should my next mod be?
    Apr 2009
    shawnee, kansas
    Really? Well I'm happy with it. Well crap I dunno what I'm gonna do next I guess. I was lookin pretty hard into a set of roller 1.85 rockers. Maybe yella terras. Can't go wrong with rockers right?
  8. #8 Re: What should my next mod be?
    Wausau, WI
    Quote Originally Posted by superv6 View Post
    do you have any knock with this setup?
  9. #9 Re: What should my next mod be?
    Apr 2009
    shawnee, kansas
    Quote Originally Posted by Liquifire View Post
    You know I've never scanned it,but like bluegtp said it must be runnin pretty good cuz I pulled off a 14.1 quarter mile time in 85* heat. If I do have kr it can't be much
  10. #10 Re: What should my next mod be?
    realisitically you cant expect any of those things to give you a big gain. im just being honest.
    if i HAD to pick one of those things i would do headers and then call up brian for a tune. its really what would benefit you the most at this point.
  11. #11 Re: What should my next mod be?
    Wausau, WI
    Sorry to be an idiot, but who is Brian?
  12. #12 Re: What should my next mod be?
    Rockers will create more knock with more air flow and no exhaust compinsation for them...BUT, since he has a 3" DP and PLOG...he should be fine.
    Reptile. The go to guy in the MO/KS area for tuning.
  13. #13 Re: What should my next mod be?
    usually untuned cars running a 3.4 pull anywhere from 2-8* of knock unless they are cammed or intercooled.
  14. #14 Re: What should my next mod be?
    Apr 2009
    shawnee, kansas
    well there you go. like i said ive never scanned it so couldnt tell ya for sure. sounds about right from what ive seen on other peoples cars.
  15. #15 Re: What should my next mod be?
    Just put a gallon of race gas in it and you'll be good
  16. #16 Re: What should my next mod be?
    Apr 2009
    shawnee, kansas
    lol. probably. i use 91 all the time right now. sometimes ill find a gas station that has 92 octane
  17. #17 Re: What should my next mod be?
    I mean at the track...just pump in like 5 bucks worth
  18. #18 Re: What should my next mod be?
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    It's like 103 or 105 around here - sure to kill a couple * of KR.
    Spend some of the cash on a tune. Save for cam, Gen V, and one of those cool chrome valve cover breathers.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  19. #19 Re: What should my next mod be?
    Apr 2009
    shawnee, kansas
    yeah i know what u meant nick. i never intend on doin a cam, and the gen V would be kinda cool, and prob. pretty cheap, but i dunno. i mean really, whats the benefit at this point? i already have a stock blower with 3.4 pulley. the gen V's flow better and all, but would it really make any diff over my setup now? i guess if i planned on doin a cam, ic setup, meth inj and all that cool ****e then i could see using the gen V's better flow.
  20. #20 Re: What should my next mod be?
    Aug 2008
    Long Island, New York
    dont get SSAC headers. save up for some good ones, or get a plog, and some roller rockers.
mod
