Thread: Ideas for a high 12's low 13's build?
Results 1 to 16 of 16
  1. #1 Ideas for a high 12's low 13's build?
    Apr 2009
    stockton ca
    Ok my origenal plan was going to be cammed and inter cooled now im thinking no intercooler but not sure
    heres what im thinking so far
    s1x cam
    head work Using l32 heads
    Headers Any input here I was thinking pacesetters
    Fender well Intake with K&N filter TDC
    new coil packs (its time)
    Wires from TDC
    180 tsat
    colder plugs
    bigger radiator
    ls1 tb maf? input here
    hptuner and dyno tune
    pulley drop 3.2 maybe with mps not sure wich manufacturer yet
    ported supercharger and lim
    maybe start with an l36 block
    And since my tran is on the way out there will be a triple edge trans to put the power to the street
  2. #2 Re: Ideas for a high 12's low 13's build?
    Jan 2009
    Grand Rapids, MI
    I have the XS Performance headers I bought off ebay for around 350 shipped and they are stainless. I've been running them around a year and love them. You won't need a bigger MAF untill you upgrade your TB. You can find alot of used N* on the forums. I'm running the ZZP 78mm TB with my stock MAF with no issue. The ba part is they cost $350. If you plan on modding the car more in the future you should go with the MPS. Bigger radiator isn't nesasary but would be nice. You could pic up a used SSIC for the price of a larger radiator and see alot bigger gains. Everything else looks good.
    XP~GEN V~SSIC~2.8~HEADERS~P&P HEADS~78mm TB~SLP LOUDMOUTH
    318 whp, pump 92 octane, 18" wheels
    Before Gen V
  3. #3 Re: Ideas for a high 12's low 13's build?
    TDCRacing
    Guest
    Sounds good so far. If you need some ported heads just let us know. We have some sitting here now that we just got in. Also you know we do blower and LIm porting right?
    Let us know if you have any more questions about your build. You will def need an LQ4 MAF sensor.
  4. #4 Re: Ideas for a high 12's low 13's build?
    why would you go with a cam you can use on stock heads when you plan on using ported heads? doesnt make sense to me. if youre going cam only you want to go bigger.
    if you want to get an intercooler the cam choice isnt going to matter AS much.
  5. #5 Re: Ideas for a high 12's low 13's build?
    Apr 2009
    stockton ca
    Well s1x is my choice before i was going to get head work done
    When i posted I had a bunch of thoughts running through my head
    I still have to find out about the head work cost and who will be doing it and so on
    As far as the i/c goes It will be another $1000 that id really like to send to my matco tools rep and get some shiny new toys sent my way
  6. #6 Re: Ideas for a high 12's low 13's build?
    headwork at an engine shop should be anywhere from $400-1000 depending upon what you have done, but either way youll have better heads than any of the vendors sell.
  7. #7 Re: Ideas for a high 12's low 13's build?
    Banned - Busted For Scamming
    Feb 2009
    You should just get an intercooler tha way you could throw some crazy boost at it, high 12's is a possibility then.
  8. #8 Re: Ideas for a high 12's low 13's build?
    he is right, an intercooler will be more effective than a cam only.
  9. #9 Re: Ideas for a high 12's low 13's build?
    Apr 2009
    stockton ca
    Yea I may be putting off buying tools till spring Or I may just add an intercooler in spring either way
    ic setup,cam,headwork,and hp tuner will put me at around 2600 then trans and tc another 2000 I guess that aint to bad Ive spent more on cars and got less performance for it
  10. #10 Re: Ideas for a high 12's low 13's build?
    yeah, with that setup you should easily be able to pull off a run in the 12s. how deep into the 12s depeneds on the tune and the driver.
  11. #11 Re: Ideas for a high 12's low 13's build?
    Apr 2009
    stockton ca
    considering the drivers a big boy Ill be happy just to see the 12's mark lol
  12. #12 Re: Ideas for a high 12's low 13's build?
    TDCRacing
    Guest
    lol
  13. #13 Re: Ideas for a high 12's low 13's build?
    it depends how often you wanna drive it...if i had a better trans id be pretty close to your numbers with a stock cam...there are many routes in getting to your goals you just need to figure out exactly what you want
  14. #14 Re: Ideas for a high 12's low 13's build?
    I have spent $1k on fueling upgrades along to get to 12's (over half of that was for fuel rails and -an stainless lines though). Granted, I did it with a rocker setup. Just something to keep in mind thought, at the level of performance you are after you will be at the limit of a stock fuel setup.
  15. #15 Re: Ideas for a high 12's low 13's build?
    Jan 1970
    Maquoketa, Iowa
    There is the overall driveability of the car too when deciding on a cam, the powerband changes enough to make an XPZ'd car no fun to drive on the street when compared to a medium cam such as the S1X.
    He should hit mid 12's with just a S1X cam if the tune is right.
    Quote Originally Posted by GTPrix View Post
    He should be fine with a rewire and 42.5# inj. These stock rails have been pushed to 600whp without any ill affects.
  16. #16 Re: Ideas for a high 12's low 13's build?
    Apr 2009
    stockton ca
    Quote Originally Posted by FoSHO99 View Post
    Im pretty sure im sticking with the s1x cam anything to wild will be harder to tune and harder to smog with.
    Im also sure im going with tog's (carb legal) and the lucas? 42.5# injectors,ported heads, and then a good dyno tune. Plus all the little things in there debating on getting a n/a block though depends on funds. Ill have the T3P trans ordered as soon as i get an email back
    In all reality I dont need a 12 sec car but it would be nice to know the powers there.
    Im going to the strip with my car stock and trans thats on the way out.. To see where its at then ill go once the new build is broke in and see where i took it to other wise probably wont see much "track time"
  1. so who thinks i can get low 13's???
    By 2000GTP in forum Off Topic Discussion
    Last Post: 07-27-2009, 05:45 PM
  2. Looking for low 13's, HELP
    By gtp59 in forum General Tech Discussion
    Last Post: 05-08-2009, 08:49 AM
  3. Will this combo work for mid 13's??
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2008, 08:40 AM
