Thread: tcs light
Results 1 to 16 of 16
  1. #1 tcs light
    GT Level Member EmEaston24's Avatar
    Pittsburgh
    last night after the blink 182 concert (which was awesome) i was waiting forever to get out of the parking lot, so i shut my car off. and when i tried to turn it back on it wouldnt start, so i tried again and it wouldnt start so i gave it some gas and it finally started up. and the tcs light came on... but the tach still worked. i had that happen before but on a different engine. any input on this? thnks
  2. #2 Re: tcs light
    Charles City, IA
    The traction control has nothing to do with the engine.
    SMGPFC Two Nipple General
  3. #3 Re: tcs light
    Pittsburgh
    ya but when the crank position sensor goes the tach goes to zero and the tcs light comes on
  4. #4 Re: tcs light
    TDCRacing
    Guest
    It could be the 10Amp fuse in the engne compartment fuse box.
    Check that and let us know.
  5. #5 Re: tcs light
    Wausau, WI
    Quote Originally Posted by EmEaston24 View Post
    does your tcs light come on every time that you start your car?
  6. #6 Re: tcs light
    Pittsburgh
    no just that time
  7. #7 Re: tcs light
    Like The OP TDC said...check the fuses
  8. #8 Re: tcs light
    Pittsburgh
    Quote Originally Posted by TDCRacing View Post
    which fuse are you talking about exactly?
  9. #9 Re: tcs light
    TDCRacing
    Guest
    It's a Mini 10AMP red fuse in the fuse box that is in the engine compartment. After you take the cover off, Look on the underside of the cover and look on the fuse list. It should say something like HVAC/TCS and something else.
  10. #10 Re: tcs light
    Pittsburgh
    checked the fuse and it looked fine. this morning i was about to leave for work and it wouldnt start. kept trying for 5 or so minutes then it finally fired up. the tcs light didnt come on tho.
    ^oh and btw, i love the aeroforce.
  11. #11 Re: tcs light
    Wausau, WI
    could this be the fuel pump relay? Are you aware of the tab bend to make the fuel pump go into high flow mode? What year is your car?
  12. #12 Re: tcs light
    Pittsburgh
    its a 99 and no i have no idea what your talking about
  13. #13 Re: tcs light
    Wausau, WI
    read this.........not sure if this helps you at all or not.........http://www.grandprixforums.net/f81/m...elp-19450.html
  14. #14 Re: tcs light
    Pittsburgh
    possibly. will putting the fuel pump in high mode take my mpg's down?
  15. #15 Re: tcs light
    Wausau, WI
    I dont think it would, but I have never done this so I am not sure at all......this is not a permanent fix, just trying to see what your problem is........
  16. #16 Re: tcs light
    the fuel line has a return line. any fuel that isnt being used goes back to the tank. you wont use any more gas, but the fuel pressure will be elevated.
  1. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  2. oil light
    By beto6169 in forum General Tech Discussion
    Last Post: 04-27-2009, 11:10 AM
  3. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  4. Gas Cap Light
    By uti grand prix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-24-2008, 01:20 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
