Thread: Misfire like no other
Page 1 of 3 123 LastLast
Results 1 to 20 of 50
  1. #1 Misfire like no other
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    ok today i finally hooked up a scan tool to look at all my sensors and stuff and just to check on it plus i had what i beleived was a misfire well it is misfiring and its just one cyl, but it only misfires at idle. #4 is the only cyl. misfiring. well i think it might be a manifold gasket. any other ideas would be well appreciated.
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  2. #2 Re: Misfire like no other
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by MTXGTP View Post
    Plug, plug wire, coil pack?
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: Misfire like no other
    wamego,KS
    nope all tested good plugs new wire is new ive tested the coil pack.
  4. #4 Re: Misfire like no other
    St Louis MO
    sure sounds electrical since it is only present at idle and only one cylinder.
    2010 Camaro SS LS3
  5. #5 Re: Misfire like no other
    wamego,KS
    ive seen it where a manifold will not seal and allow unmetered air into the cyl. causing a miss fire.
  6. #6 Re: Misfire like no other
    St Louis MO
    sounds like you know what the problem is, yes?
    ok let me backup you have a leak at the exhaust manifold gasket, and that would cause a misfire? Wouldn't running open headers cause a misfire on all cylinders then?
    2010 Camaro SS LS3
  7. #7 Re: Misfire like no other
    wamego,KS
    no at the LIM no im not sure cause i did a coolant pressure check and found out that im losing pressure but i have no leaks externally. im wondering if coolant could cause an miss fire.
  8. #8 Re: Misfire like no other
    Saraland Alabama
    yes it can
  9. #9 Re: Misfire like no other
    St Louis MO
    ^^^ agreed on the coolant since it can kill the spark or combustion.
    2010 Camaro SS LS3
  10. #10 Re: Misfire like no other
    Bastard Reptile's Avatar
    Kansas City, MO
    I had this problem today actually...on a local's car. A slight coolant seep was killing one cylinder. Bad gasket in his case.
    Is your plug wet from coolant?
    Test to see if you have any spark at that plug. Pull it, and then put the boot on it and hold it with some insulated pliars. Have someone crank on it while you watch for a spark.
  11. #11 Re: Misfire like no other
    wamego,KS
    ok but last time i tried this i got a not so very nice shock.
  12. #12 Re: Misfire like no other
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    insulated pliers and a glove, man
  13. #13 Re: Misfire like no other
    Kansas City, MO
    That's why I said insulated pliars.
    But if you said that you pressurized the coolant system, and it's bleeding off....you will need to find the leak. It could be going into the intake, or worse going into the block. If you think that you have it pegged at which cylinder it is, then pressurize the system again, wait for it to bleed off and check that plug. If it is going into the cylinder the plug will be soaking wet, and you have found your problem.
    New intake gaskets could be in your future.
  14. #14 Re: Misfire like no other
    PA
    If this much coolant was going into the cylinder and fouling the plug to where it won't spark, I would imagine it would be very difficult to start. Do you find it hard to start at all?
    2001 GSE
  15. #15 Re: Misfire like no other
    Banned
    New Port Richey Florida
    I'm laying money on a plug going dead. I had the same problem were a plug just went dead all of a sudden. is the car running rich? One sure fire way to tell if your burnning coolant with the car running smell the exhaust gas's if they smell sweet then the cars burnning coolant. Keep us posted on whats going on
  16. #16 Re: Misfire like no other
    SW Chicago Suburbs
    if you're burning coolant, you also may see white smoke from the exhaust...
  17. #17 Re: Misfire like no other
    Saraland Alabama
    but not always (I had a truck came in with a cracked head and no gasket that showed no smoke or smell)
  18. #18 Re: Misfire like no other
    wamego,KS
    ok well today on the way home i started to get a miss fire during boost so plug has fouled. so would you say a intake or a head gasket if its an intake ill start on it tomorrow.
  19. #19 Re: Misfire like no other
    St Louis MO
    Don't you have to pull the LIM to get to the heads off? My vote is LIM gaskets. But that is just going by historical data.
    2010 Camaro SS LS3
  20. #20 Re: Misfire like no other
    wamego,KS
    yea you do have to casue the LIM bolts to the heads
