Thread: Misfire like no other
Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
  1. #41 Re: Misfire like no other
    Oklahoma
    My immediate assumption would be over tightening of the plugs, but it looks weird. Like it (the ignition voltage) found pores in the ceramic and arced up the plug.
  2. #42 Re: Misfire like no other
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    i kno that the spark is going into the insulator instead of through the plug
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  3. #43 Re: Misfire like no other
    Saraland Alabama
    I have seen that a few times, and only with the AC plugs (when at the dealer we had a bunch of cars with that problem) not sure the cause of it other than possibly poor workmanship in Mexico (delco quality suffered after the sell off)
  4. #44 Re: Misfire like no other
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    looks like it started as just cracked porcelain, went worse from there....what you see as dark deposits is some form of residue (carbon?) from the spark funneling through the porcelain, the longer it goes this way, the more cracks develop
  5. #45 Re: Misfire like no other
    wamego,KS
    yea Cause NGK makes the AC delco plugs.
  6. #46 Re: Misfire like no other
    Oklahoma
    So Im assuming that replacing these has fixed the misfire issue?
  7. #47 Re: Misfire like no other
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by MTXGTP View Post
    You sure about that? I and many others run NGK w/o issues.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  8. #48 Re: Misfire like no other
    St Louis MO
    Carbon tracking:
    Carbon tracking leaves dark lines, possibly looking like cracks, permanently etched into the spark plug ceramic and rubber of the boot. Carbon tracking cannot be rubbed or cleaned off by any means.
    Higher peak cylinder pressures require higher demand voltage for spark plug operation. Higher demand voltage increases the stress on the spark plug to spark plug boot dielectric interface, such that contamination and air gaps between the spark plug and boot can cause this interface to breakdown. A break in the dielectric interface can allow the spark to find a path to ground other than the center electrode. These paths or carbon tracks are etched into both the spark plug and the spark plug boot
    I would pull the spark plugs out and look at them closely to see if there is any evidence of carbon tracking. To correct this condition, it is necessary to change both the spark plug wire and the spark plug at the same time on only the cylinder involved. Changing only the spark plug or only the spark plug wire will not prevent the carbon tracking from recurring. Carbon tracking will happen again in the same location much quicker if half of the track is still available. Recurrence of the same problem is likely in as little as 1,000 miles if the carbon track is not totally removed
    2010 Camaro SS LS3
  9. #49 Re: Misfire like no other
    Saraland Alabama
    I have had some that were stamped champion on the metal part (lowest bidder maybe?)
  10. #50 Re: Misfire like no other
    wamego,KS
    ^^^ i would say so
    i ordered some taylor wire and some autolites i hope this crap finaly quits.
