only sure way to tell is a tear down
yea i kno its just more work than i want to do
The one Reptile was talking about actually had the supercharger gasket hanging up on the coolant o-rings that run thru it and it was sucking coolant from there. You might look it over really good after you get the supercharger off and you may not need to go any further if yours is getting sucked in there also.
It's a shame you're so far out there, or I'd offer to help.
Now, just to say something else. It is most likely NOT a head gasket, and I'll tell ya why. If it were one, the cylinder pressure would eventually blow the top off of your overflow bottle. The manifold pulls vacuum, which is probably why your engine is only sucking coolant. But, once you get the manifold off it should be pretty clear where the coolant is coming in at. It always leaves a trace.
To that point, I once read an old school troubleshooting technique where if you have a bad/blown head gasket you let the car sit over night, then go out and start it up and grap the upper radiator hose. If the head gasket is bad, that hose will pressurize within seconds of the engine being started.
ok well i checked for coolant in the cyl. no coolant on plugs. right now im more worried about this miss fire the coolants not in the oil so not to worried. well this miss fire seems to be bad plugs. the bad thing is the spark is not going through the spak plug instead it sparks off to the insulator. spak plug or wire. (the wire is a cheep set i bought last summer.
may as well replace both the cost isn't that much really
What plug will last the longest. and for wires MSD's or or Taylor.
For the best performance go sc delco plugs and wires plgs there wiers are lifetime warranty sp?
i really dont mind changing them but the last 2 sets or plugs have barely lasted me 6 months. first set was NGK second was AC delco platinum. i just want a plug that doesnt cost 50 bucks a set.
Autolite plugs cost me like a buck a piece or something from Wal-Mart. I run AL605's.
Im looking at taylor wires shoould i get the thunder volt or the spiro pro.
is 104's the factory heat range
I dont think so. Im sure someone will correct me if Im wrong, but I thought 606's were stock heat range.
have you ever seen this and do you know what might cause this.
oops a lil big but you can see what im talking about.
