Thread: m90 bypass valve question
Results 1 to 11 of 11
  1. #1 m90 bypass valve question
    SE Level Member bhrfpa11's Avatar
    Nov 2008
    Palmer, Alaska
    so i was wondering if its even possible to do a mod to the supercharger and make the bypass valve stuck open so the supercharger is functional at all times. and what the pros and cons would be. one bad thing i know already is decreased mpg...anything else good or bad about doing this? or eevn how to do it?
    Black 2000 GP GTP: Rockford Fosgate all around, HID's, K&N FWI.
    <- yup. thats alaska.
  2. #2 Re: m90 bypass valve question
    you wouldnt want that. trust me.
    you could JB weld the plunger so the valve is closed, but it would cause all kinds of problems. DO NOT DO THIS.
  3. #3 Re: m90 bypass valve question
    Banned - Busted For Scamming
    Feb 2009
    if the bypass were open all the time, you would have no boost
  4. #4 Re: m90 bypass valve question
    Nov 2008
    Palmer, Alaska
    well i didnt necessarily meaN open. i meant like whichever way made the supercharger active at even low rpms. just curious...what would happen?
  5. #5 Re: m90 bypass valve question
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Cons:
    a bunch more heat
    more parasitic loss resulting in the fuel economy loss you mentioned, but also putting more wear on the engine
    Possible rougher running engine
    More part throttle burst knock
    Pros:
    2001 Buick Regal LS - Almost Stock
  6. #6 Re: m90 bypass valve question
    Quote Originally Posted by Scimmia View Post
    That is the one I was going to mention...beat me to it
  7. #7 Re: m90 bypass valve question
    Aug 2008
    Long Island, New York
    not meaning to thread jack but i recently "fixed" my BBV problem by plugging the lower line and leaving the bbv nipple open to the atmosphere. will this give me trouble?
  8. #8 Re: m90 bypass valve question
    QCA, IA
    Quote Originally Posted by 2000GTP View Post
    No, that's totally different. You still have a fully functioning, vacuum operated BBV; the computer just can't interfere with it anymore. We're talking about totally disabling it and blocking the valve shut like some of the Fiero guys do
  9. #9 Re: m90 bypass valve question
    Nov 2008
    Palmer, Alaska
    i was just thinking that sine the valve keeps the blower from working at low rpms that if it was disabled then the blower would work at all rpms...
  10. #10 Re: m90 bypass valve question
    QCA, IA
    Quote Originally Posted by bhrfpa11 View Post
    It's not about RPM, it's about vacuum levels. At low vacuum (high throttle position), the BBV is closed, so even at low RPM, the blower is pushing air if you push the gas. All this could do is cause more boost at part throttle, but why not just push the throttle more? There's no gains to be had that I know of, and plenty of potential problems.
  11. #11 Re: m90 bypass valve question
    Nov 2008
    Palmer, Alaska
    very, very true. just curious thanks for the info
  1. bypass the amp...
    By PonchoDvr4Lfe in forum Audio, Security & Visual Electronics
    Last Post: 07-30-2009, 12:07 PM
  2. Boost Bypass Valve Questions....
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 08:25 AM
  3. Boost Bypass Mod????
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2008, 11:04 AM
  4. HELP! Bypass alarm!
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 05-03-2008, 06:07 PM
