Thread: will i see a big temp drop using phenolic
Results 1 to 8 of 8
  1. #1 will i see a big temp drop using phenolic
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    just like the title says im trying to find a way to get my heaton to run more cool so is it worth it to use a phenolic spacer or ic and if so who sells a phenolic ic core besides mini chopper cuz im having my doubt about buying off of him
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: will i see a big temp drop using phenolic
    ZZP Sells one...but your wasting your money...
  3. #3 Re: will i see a big temp drop using phenolic
    its really wont help all that much. the air isnt in the blower and lower intake long enough to take the heat from the motor. the only reason its heating up is because of the blower.
  4. #4 Re: will i see a big temp drop using phenolic
    Jan 2009
    Tallahassee, FL
    Just go ahead and get 2 spacers with a heat exchanger in the middle of them. Problem solved.
    It's not the blower being hot as the main problem, it's the air getting hot because of the rotors compressing the air.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  5. #5 Re: will i see a big temp drop using phenolic
    alright thanks for the input gues ill just stay with a reg ic
    sold 97 GTP stock
  6. #6 Re: will i see a big temp drop using phenolic
    You can't even begin to compare even an intercooler to a spacer...thats like comparing Meth Injection to a TB Spacer...two totally different things.
  7. #7 Re: will i see a big temp drop using phenolic
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    he was referring to phenolic IC cores, too.
    phenolic doesn't transfer heat as easily, but the difference isn't worth the extra cost over a normal IC. oh yeah, i'm pretty sure mini hasn't had much business as of late...
  8. #8 Re: will i see a big temp drop using phenolic
    ya i was gunna buy one from mini cuz it cost the same as a ssic core from zzp so i though for the same price i could get a phenolic core from mini but after read blues thread that wont be happening
    sold 97 GTP stock
  1. XP or Phenolic SS IC?
    Last Post: 06-30-2009, 01:19 PM
  2. Phenolic SSIC
    By minichopper6hp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2009, 05:57 PM
  3. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
