Thread: not making "full" boost
Results 1 to 17 of 17
  1. #1 not making "full" boost
    Aug 2008
    Long Island, New York
    i decided to floor my car today for whatever reasong and i realized that i seem to not be making full boost on the meter on the DIC. could it be because of my new mods (roller rockers, pulley, and tune)
  2. #2 Re: not making "full" boost
    TDCRacing
    Guest
    No.
    Something is wrong with your BBV. Possibly the vacume line going to it. And there is a slim chance it could be something related to the VAC line going to the MAP sensor.
  3. #3 Re: not making "full" boost
    Donating Users mystic231's Avatar
    Michigan
    I also had a problem with my linkage getting stuck, had no boost at all. Probably as a result of MI winters or something. Anyway, hosed down with WD40 and worked it a bit and all is good.
    There is also a chance that you have a leaky diaphram inside the BBV due to age or whatever. ZZP sells new ones.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  4. #4 Re: not making "full" boost
    canada
    this might help dont know, helped me
    http://www.grandprixforums.net/f18/n...ost-17822.html
    1998 GTP 2Door
  5. #5 Re: not making "full" boost
    the DIC is stupid, get a mechanical boost gauge to know fo real. if youre only getting 4-5 psi then yes, the BBV is messed up somehow.
  6. #6 Re: not making "full" boost
    Aug 2008
    yup plugged the line bbv was the problem... was only getting like half boos on the dic and yea bio im plannin on getting a real boost gauge soon enough. all i have to say is on full boost my car feels like a monster now
  7. #7 Re: not making "full" boost
    Aug 2008
    im really looking to get a 3 gauge pillar pod. i want to put an aeroforce in it, i guess a boost gauge and something else
  8. #8 Re: not making "full" boost
    TDCRacing
    Guest
    Glad you got it fixed
  9. #9 Re: not making "full" boost
    canada
    Quote Originally Posted by 2000GTP View Post
    that was exactly my problem. i just got an aeroforce last week good buy
    1998 GTP 2Door
  10. #10 Re: not making "full" boost
    Aug 2008
    yup thank you guys
  11. #11 Re: not making "full" boost
    Donating Users
    Plainfield, IL
    i have a dual pod with a aero and boost...perfect lots of info no rediculous cockpit look
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  12. #12 Re: not making "full" boost
    i need to take pictures of my cockpit...hah.
    i have: volts, oil pressure, boost, fuel pressure, and a wideband.
  13. #13 Re: not making "full" boost
    Aug 2008
    i think ill do boost and oil pressure, then save up for an aeroforce so i can display whatever the hell i want on it and scan for stuff. i actually like the look of the pillar gauges in the car but of course thats not my sole reason for doing it
  14. #14 Re: not making "full" boost
    Not to jack the thread...but anyone have a pic of this plugged BBV? I know every one talks about it...how much does it actually benefit one to do this?
  15. #15 Re: not making "full" boost
    Aug 2008
    i dont think its actually a benefit... but its just a fix for if you cars not makin full boost. because i dont think the bbv is really necessary from what ive read
  16. #16 Re: not making "full" boost
    do not plug it, just disconnect the vacuum line. leave it open to the atmosphere on the lower nipple. it really doesnt do much, but it just makes it so that the BBV can be completely vacuum controlled so you can tune around the PCM dumping boost.
  17. #17 Re: not making "full" boost
    Aug 2008
    you are supposed to plug the line itself though right? not the BBV nipple
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. Car "shuttering" under moderate boost?
    By CDoran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 09:25 PM
  3. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
  4. HELP Not making full boost
    By 1slowhatch in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2009, 01:31 PM
