Thread: What could this be?
Results 1 to 9 of 9
  1. #1 What could this be?
    MI
    I have a 2000 Grand Prix GTP and as soon as I get up to about 20 mph I start to hear a noise in the front end that sounds like something is winding up. The faster I go the louder it gets, almost sounds like the wheel is rubbing something, even though it's not. Car has never done this before. I also have a cold air intake just to give you guys a little more info. Car doesn't make the sound when ideling. Any ideas what I should check? Thanks,
    Brendan
  2. #2 Re: What could this be?
    in a house
    Quote Originally Posted by beejay76 View Post
    Brendan
    Maybe a wheel bearing. Does the noise go away if you swerve one way or the other?
  3. #3 Re: What could this be?
    MI
    Quote Originally Posted by silverstreak View Post
    Just took it out for a spin. No, noise stays whether you turn or not, just gets louder the faster you go. Sounds like the wheel is rubbing something but I know it's not???
    Brendan
  4. #4 Re: What could this be?
    Wausau, WI
    Please tell me that you don't mean your supercharger..........
  5. #5 Re: What could this be?
    GT Level Member BoostedComp's Avatar
    Youngstown
    ^^^ haha thats what i was thinking when i first read it if you just put the air intake on.. the whine will be alot louder than it was which is what you may think it is
  6. #6 Re: What could this be?
    MI
    I bought the car a few months ago and the Air Intake was already installed, and still sounds the same. I noticed you guys mentioned the Supercharger maybe going bad. How can you tell? The noise happens regardless if the supercharger kicks in or not. Also does not make the noise when just idling or at a stoplight in gear. Tires are fairly new but I'm going to switch the back to the front and see if that makes a difference. Could have a bad tire in the front???????? Thanks guys! Any other suggestions are greatly appreciated.
    Brendan
  7. #7 Re: What could this be?
    Hub assembly...they can make all sorts of funky noises.
  8. #8 Re: What could this be?
    MI
    Got it looked at and come to find out, it was the wheel bearing. I've had plenty of bearings go out on my cars but none that sounded like this. Thanks guys!
    Brendan
  9. #9 Re: What could this be?
    GT Level Member l3enner's Avatar
    Niagara Region, Ontario, Canada
    damn those wheel bearings. haha
    what brand did you replace it with?
    local garage around here uses "FAG" wheel bearings... not going on my car. haha
    Bruce Benner - Niagara Region, Ontario, Canada
    2004 Grand Prix GT2 - Tinted Windows,Tail lights, 20" Velocity VW166 rims...
