Thread: My Car eats sparkplugs!
Results 1 to 18 of 18
  1. #1 My Car eats sparkplugs!
    SE Level Member MidnightSpecial's Avatar
    Apr 2009
    Minnesota
    Hey guys I have a 2000 Grand Prix GTP coupe. Ok so when I first bought it I noticed it had a small miss, then I drove it for about 2 weeks and the miss got very, very bad! I pulled the spark plugs and Plug #1 on the front row of cylinders was finger loose and it was missing the electrode and part of the middle piece. I pulled all the other plugs and they were at least all in one piece there but what I believe to be the original AC/Delco iridium spark plugs! My car has 155,000 miles on it by the way. So I do a compression check on cylinder #1 and guess what? 0 psi. Shoot. All the other cylinders were in range. So me and my dad pull of everything to get the head off and go to the junkyard to get a used one. Then we took it to some shop to have it boiled and checked for cracks then had the seats done and new valves and valve stem seals put in. Put it all back together with Autolite Platinum plugs. Runs really good for about 400 miles then it started missing again. Pulled the plugs and they all looked like complete crap! Cylinder #2 in the back was missing the electrode completely and Cylinder #5 was missing part of the electrode and all the other ones were bent way out and looked like they were about to give. So I did another compression check and what a relief all the cylinders were good. This time we put AC/Delco iridium plugs in and I just got done installing that 4" custom FWI. It ran good for about an hour (BTW My gas mileage went from 20mpg to 18.3mpg after that FWI) and then when I brought it home and listened to the exhaust it sounds like its missing again!!! My dad has a scanner so that will be the next thing I do and I'll post the results.
    Thanks for any help!
  2. #2 Re: My Car eats sparkplugs!
    Becca Boo MizzBecca's Avatar
    Michigan
    Damn your car eats spark plugs I hate when that happens.
    I drive a POS
  3. #3 Re: My Car eats sparkplugs!
    Any mods? Sounds like something is going wrong here...
  4. #4 Re: My Car eats sparkplugs!
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    That is the #1 sign of chunked pistons! But if you pulled the heads and you looked at the pistons to make sure there were no cracks or chips then See step 2
    2. Dump the platinum plugs. Go copper
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  5. #5 Re: My Car eats sparkplugs!
    Apr 2009
    Minnesota
    The only mod I have so far is that FWI I just put in. When we pulled the front head all of the front cylinders and pistons were perfect. I'll let you guys know what codes are showing asap.
  6. #6 Re: My Car eats sparkplugs!
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    First - welcome aboard!
    Secondly - you have to be the luckiest (believe it or not) SOB on the planet. TooFast is right - you have a detonation issue - pure and simple. Now...what's causing it...that's unclear. I would suggest taking those coil packs off and inspecting/cleaning and/or swapping them if possible. That's the first easy check. Secondly - you need to have that PCM flashed to stock and case-learned - ASAP. I'm thinking that you have a PCM that has been reprogrammed and you have some...issues to say the least.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  7. #7 Re: My Car eats sparkplugs!
    SE Level Member Robotech's Avatar
    California
    No kidding. Something is surely amiss... Seriously though, with that many miles and your lack of mods the only other thing I can think of other than what has been mentioned is VERY heavy carbon build up. If you have pieces of carbon coming off they can cause this kind of damage too. Other than that...I'm at a loss.
  8. #8 Re: My Car eats sparkplugs!
    There is this AWESOME cleaner from Mopar that they call Combustion Chamber Cleaner. Use that if there is a heavy build up of carbon. You have to order it online but it is the shiz.
  9. #9 Re: My Car eats sparkplugs!
    Apr 2009
    Minnesota
    Oh I forgot to mention what had caused the 0psi of compression in cyl #1 before. The exhaust valve had a nice chunk missing out of it from coming down on an uneven seat because the head was cracked. I just ran the codes and this time it was cyl #4 misfire and the 440 Evap Emissions system malfunction. I pulled the #4 plug and its in perfect condition. So I did a compression check and now I'm getting about 135psi when before I was getting 150-155 on that cylinder. The front ones all have 170. The motor was still a little warm when I did the compression check so then I was thinking maybe the rear head is cracked and the compression goes down when the motor is warmed up and everything expands. So I ran the car up and down the road to get it up to temp (about 185 or so) and then listened to the exhaust for a miss. Didn't hear one? weird. Then I did a compression check on #4 while everything was still nice and hot. Compression still read 135psi. Another thing I thought of , how many times should you crank it over to get an accurate reading? Before I would only turn it over 4 or 5 times and get 150, this time I would only get like 90psi with 4 or 5 cranks. I have to crank it about 15 times or so to get 135-140 psi.
  10. #10 Re: My Car eats sparkplugs!
    Rings might be bad in the pistons...
  11. #11 Re: My Car eats sparkplugs!
    TDCRacing
    Guest
    4 or 5 seconds while cranking it is normal.
    I'm not understanding how everything was ok on the cylinder walls and pistons when you said a peice of your #1 #2 spark plug fell into the engine while it was running. I'm also not understanding how a tuned PCM could make your spark plugs fall apart.
    So your telling us that when you dissembled the engine down to the bare short block to get it hot tanked that the cylinder walls were not scared at all?? Since you had it apart you should of at least honed it and put new rings in it.
    As far as the problem with the plugs i'm not sure. Other then chipped pistons or you installing the wrong plugs or installing the plugs without the washer on them i'm not sure what is going on or what could cause that.
  12. #12 Re: My Car eats sparkplugs!
    Apr 2009
    Minnesota
    TDCRacing,
    I never removed the back cylinder heads, sorry if I made it sound that way. I just removed the front cylinder heads and bought a used one then had the used one boiled to make sure there was no cracks before the place refurbished it. I never took the engine out of my car.
    I didn't think that you could remove the washer from the spark plugs? Isn't it too small to fit over the threads?
    A new Idea I have, My car was totalled out from a blow to the front drivers side fender. I bought it from a Body shop that had restored it. When I took the Airbox out I see that it has been damaged and repaired with some sort of resin or JB weld type of stuff. I'm thinking maybe the PCM was internally damaged in the crash, or the original PCM was destroyed and they put either the wrong one in (say one from a GT or SE) or they put one in from a junked GTP that some kid had reprogrammed for way too much spark advance or something along those lines. Another thing that causes me to think this is that the miss seems to come and go. I was driving it right after installing the new AC/Delco plugs (OEM) and everything was working right then I decided to bring it up to 113mph for a very short period of time then when I brought it home I could here a small miss and it had the Code (Miss on Cyl #4). Then I came back and started it the next day and it didn't start missing until 5mn or so after the car was running. (Its not a Major miss like it was with the broken valve its more of a slight popping every other second or so) Then I shut it off and let the car cool down then started it and it didn't miss. I drove it a few miles to get it up to temp fully and brought it back home and it still wasn't missing? This was the last time I drove it BTW. (Also I deleted the Cyl #4 Miss code the first time I started my diagnosis and now after running it 2 seperate times the code has not come back)
  13. #13 Re: My Car eats sparkplugs!
    Wausau, WI
    do you have a chance to get a scan gauge to put on it so that you can actually see what is going on? I would GUESS that it is something in the PCM as well with the information presented so far.....fwiw
  14. #14 Re: My Car eats sparkplugs!
    Wausau, WI
    does this car have the original sized pulley on it?
  15. #15 Re: My Car eats sparkplugs!
    Quote Originally Posted by Liquifire View Post
    I asked that earlier...all he said that was done to it was a fenderwell intake...that's why my "too small of a pulley" idea went right out the door...
  16. #16 Re: My Car eats sparkplugs!
    Wausau, WI
    he said that the only mod he did was put in an FWI...........I didn't know if he checked for pulley size from a previous owner? Didn't mean to confuse anyone..........
  17. #17 Re: My Car eats sparkplugs!
    Apr 2009
    Minnesota
    Thats one thing my dad suggested too so I measured the pulley and it was about 4" on the outer edge but the belt sits down in it a little farther so I am guessing that is a 3.8" stock pulley, there isn't any numbers or brands stamped on it and its just plain semi-gloss black.
    Liquifire- All I have is one of those code readers, Do you know if a guy could rent a scan gauge? How do they work and what do they tell you? Also what is a PCM Flash and Case Learn? Is there a way to tell through the numbers on the PCM if its the original or not?
    Thanks!
  18. #18 Re: My Car eats sparkplugs!
    Wausau, WI
    You might be able to tell if the pcm is the original one from the numbers on it but the outer pcm shell would not tell you anything important as it could have a modified program ....the only way to tell is to have someone with a programmer go through it. I personally don't know anyone with a scan gauge to rent or where you could get one from. Do you know anyone with an aeroforce gauge that you could use to watch it in real time with? Or someone who tunes cars should also be able to do this via laptop. I would personally take the battery and disconnect power for twenty or thirty minutes and start back up. It probably won't help any, but you never know......I am personnally not familiar with what a case learn will do for you, but find someone who can program for your car........it is cheap compared to a new motor, and all of the PITA it has been for you..........keep us posted......
    Where in minnesota are you.....which area? PM me if you wish....
  1. My GTP Eats Mustangs
    By boostjunky in forum Track Sessions and Kills
    Last Post: 04-15-2009, 02:13 PM
